Shifting in and out of EV
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by crewdog, Nov 1, 2011.
  1. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    Just wondering, is there a recommended procedure or speed range to shift in or out of EV mode while operating, or should it be done while the car is stopped?
    maybe one of the prototype drivers could answer this i hope.
    Thanks
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    No protocol. I think you just want to be logical about it. If you're slowing down and will be staying on surface roads and have plenty of battery charge then you'd want to go back into EV. If you're getting ready to do some heavy highway driving I think it would be best to force OUT of EV several minutes before then to allow the ICE to start to warm up properly.
    Other than that the car really decides pretty well on its own depending upon the charge level of the pack.
  3. crewdog
    492
    388
    Woodstock, GA
    Thanks.
    I'm sure it'll be fun figuring out the right style of finessing to match conditions.
