Shifting into neutral (towing) without HV Battery
Discussion in 'Gen 2 Prius Main Forum' started by JC91006, Jul 15, 2014.
  1. JC91006
    16,489
    8,402
    Does anyone know if the Prius can be shifted into neutral without the presence of a hv battery? I want to have a car towed that doesn't have a hv battery inside. Not sure if it can go into neutral??
    49,610
    the 12 volt allows it to shift to neutral when made ready, don't know if missing hv battery will complicate the matter.
  3. fuzzy1
    10,222
    The car needs to be towed with the front wheels off the ground, regardless of the HV battery presence / absence. So Neutral or not doesn't really matter, except possibly to make it easier to get the car into position to lift the front.
    Other threads have indicated that the car can be dragged out of a parking space. Not great for the tires, but won't hurt the car.
    xpcman likes this.
  4. JC91006
    16,489
    8,402
    The car is parked front in on a parking spot, tow truck cannot get to the front end. I need to push the car out so the tow truck can get to it. However there's no hv battery so not sure if it'll go into neutral.........and the 12v is dead!
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    can't the two truck place dollies under the front two wheels?
  6. JC91006
    16,489
    8,402
    They probably can, not really sure though. It would be easier if I can just get the thing into neutral and push it out of the parking spot
  7. bisco
    49,610
    you won't get anywhere without the 12v.
  8. JC91006
    16,489
    8,402
    the tow truck can jump that part.....
    come to think of it, I think it can be done without the HV. I remember the car can boot up with the HV orange plug taken out. That would be the same as not having an HV.
  9. jdenenberg
    jdenenberg EE Professor
    3,857
    1,856
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There is no real "neutral" in a Prius. One of the MGs has to spin to compensate for the engine standing still. The HV battery provides the energy for the MG to act as a motor so as was said earlier, either drag your Prius out or put dollies under the front wheels.
    JeffD
  10. bisco
    49,610
    i don't follow you jeff, when i'm standing still, with the shifter in 'neutral', a motor is turning?
  11. jdenenberg
    3,857
    1,856
    Trumbull, CT
    2020 Prius
    LE AWD-e
    We are discussing moving the car in neutral and the the engine is still but both MGs have to turn if the front wheels are turning. The MG on the drive shaft just turns without power when the car rolls in neutral, but the other MG has to be spun so that the motor can remain stationary.
    JeffD
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It sounds like you might not be the most Prius savvy, but be forewarned that jumping a Prius can cause major damage. If the terminals are reversed which is easy for people that do it everyday to screw up because they are going fast, you are going to blow the inverter and fusible links. Big sparks are also not good for it like attaching a live good battery to the Prius with jumper cables. Smart cables or a form of battery boost that can physically connect without being electrically connected and then electrically connect to charge.
  13. usnavystgc
    3,159
    989
    Tucson, AZ
    1) I don't doubt what Jeff is saying because he is way smarter than me
    2) On my 01, there is a release that allows one to put it in "neutral" with no power applied (not in ready, key turned off). To my knowledge, this simply disengages the park pawl or manually pulls it out. In the Gen II, the parking pawl is electric (12V). I can't remember who it was but I did see a post on here a long time ago that talked about how to jumper the parking pawl to get it to release. I'm pretty sure it was imwoody36 who is the owner of autobeyours.com.
    I would give him a call since he's not on here much anymore.
  14. usnavystgc
    3,159
    989
    Tucson, AZ
  15. JC91006
    16,489
    8,402
    Thanks for the reminder about jumping the car. I have an extra battery on hand that I can throw in there, but thought it would be faster to just use the tow truck to jump it, boot the system and get it into neutral. I'm not driving the car anywhere as it doesn't have a hv battery.
