Shims - Rear Wheel Alignment
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TwoPriusInTenn, Dec 28, 2024.
  1. TwoPriusInTenn
    217
    60
    Tennessee
    We recently had an all wheel alignment done on our daughter's 2008 Prius. When he was finished the tech said he got "the rear wheels as aligned as possible".
    Apparently there are shims that need to be replaced/installed on the rear axle beam that can only be done by the dealer.
    Anyone know anything about this?
  2. PriusCamper
    PriusCamper Senior Member
    11,981
    4,870
    Pacific Northwest, USA
    Sound like BS to me...
  3. Tombukt2
    Tombukt2 Senior Member
    12,010
    2,123
    Durham NC
    No can be done by anyone . May not have in stock .. the difference they'll make is generally very moot .
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
    Why was an alignment done? What angles are out of spec on your car?
    How does the car drive? How are the tires wearing?
    There are aftermarket shims that go between the rear wheel bearing assemblies and the axle beam. The shims are typically installed by the alignment tech - since the angles have to be checked once the install is done.
    #4 mr_guy_mann, Dec 29, 2024
    Tombukt2 likes this.
  5. TwoPriusInTenn
    217
    60
    Tennessee
    Thank you.
