Shock and strut interchangeability
Discussion in 'Prius v Technical Discussion' started by douglasjre, Oct 26, 2023.
  1. douglasjre
    douglasjre Senior Member
    1,856
    647
    Orlando, FL
    Are Prius V Shocks and struts interchangeable with the 2010 - 15 Prius?
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,917
    4,678
    Texas Hill Country
    Not based on part numbers
  3. douglasjre
    1,856
    647
    Orlando, FL
    I saw the same thing. The last five digits is different, but the way I was trained is that the last five digits denotes the model of the vehicle and the first five digits simply means that it's a shock. So of course the first five digits would be the same. Just like it is for a Toyota Avalon it would have the same first five digits. But just because the last five digits is different, would that necessarily mean that it's just a different vehicle or is it truly a different part as well?
  4. rjparker
    7,917
    4,678
    Texas Hill Country
    A v is heavier, taller and rated for more load. It also has standard 16” wheels instead of the hatchback’s 15”.
    Are your shocks leaking? If not I would leave them.
  5. douglasjre
    1,856
    647
    Orlando, FL
    Got new shocks and a lift kit in a 2010 Prius. Want to put them in the 2013 Prius v. Will they bolt up?
  6. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Maybe, but the v wagon is 300 lbs heavier than the Prius hatchback.
    It'll be like always driving around with a 300 lb dude riding in your car.
    Tim Jones likes this.
  7. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Struts look different, reference http://www.monroe.com images for the Prius and Prius v…
  8. V Sport Wagon
    V Sport Wagon Member
    227
    83
    Different struts and shocks for the V...make sure you double check your part numbers.
  9. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    NO. I bought new struts and was shipped hatchback parts and the fit was wrong....
    xliderider, jzchen and V Sport Wagon like this.
