SHOOT. Heated seat install
Discussion in 'Gen 2 Prius Accessories & Modifications' started by PriusGuy32, Feb 8, 2014.
  1. PriusGuy32
    1,417
    510
    Harrison Township, Michigan
    For those that have installed heated seats in their Priuses beneath Clazzio (or other) covers:
    The heated seat pads have adhesive strips. Did you stick the sticky side to the cloth seat, or stick it to the inside of the seat (Clazzio or other) Cover??
  2. quynvu
    quynvu New Member
    I stuck the pads between the foam and factory covers. Sticky side on the foam. It worked out pretty well and you can't tell that the pads are even there.
    usnavystgc and PriusGuy32 like this.
  3. PriusGuy32
    1,417
    510
    Thanks quynvu - I put the adhesive side of the heated pads ON to my original cloth seat. I now realize that Clazzio recommends you stick them to the inside of the Clazzio seat covers (whoops!). But I dont seem to notice any difference anyways.
  4. silverone
    silverone Member
    84
    34
    Ohio
    2014 Chevy Volt
    I did the same as quynvu. Stuck to foam. The only additional benefit to taking off the cloth was the ability to route the wiring through the seat foam towards the back, and carve out a space to accept the spot on the heat pad where things are a little thicker.
    quynvu likes this.
  5. quynvu
    quynvu New Member
    Those pads get pretty warm anyways. I'm glad everything worked out for you. :) Cheers!
  6. TLCESQ
    TLCESQ Member
    30
    31
    Has anyone put these heat warmers on the second row seats? Considering the Clazzios and since I already have seat warmers in front seats, I'm considering purchasing for back seats. Where to put controls is also a question.
