Shop recommendations around Ashburn, VA
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by thope, Aug 26, 2017.
  1. thope
    thope New Member
    VA
    2014 Prius Plug-in
    I need a recommendation for a indy shop to get the front bearing done on a 2014 plug-in 2014. Dealership quoted me $1000. Looking for someone who can do it right. Seems like a complicated repair reading up on here.
    Thanks.
  2. MattStevenson
    MattStevenson Member
    57
    35
    US
    You can easily replace the wheel hub. The bearing is inside. I did one on an old Camry a while ago.
    LG-H918 using PriusChat mobile app
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    One option down the way a bit from you is Mac's service center in Ashland.
    SFO likes this.
  4. thope
    thope New Member
    VA
    2014 Prius Plug-in
    seems a lot more involved, it have to be removed for the knuckle or something.
  5. thope
    thope New Member
    VA
    2014 Prius Plug-in
    Hi ray, do you have any experience with this shop? Your location shows that you are from CA.
    Raytheeagle likes this.
  6. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    I spent 6 years living in the greater Richmond area;).
    While I have no personal experience with them, some members here have used them.
    @wjtracy may know of one in Fredericksburg that might be a good one as well.
    Hope that helps(y).
    thope likes this.
  7. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    We do not seem to have too many special places to go for service except for standard repair shops. One member @PurcellvillePinball in your area talked about getting his work done at Progressive Automotive in Hamilton.
    PS- you may want to call Toyota USA to see if they could cover as that is a strange repair
