Short extension cord for PiP? (~6 feet?)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by eyespii, Feb 12, 2013.
  1. eyespii
    eyespii Junior Member
    48
    2013 Prius Plug-in
    I don't understand why toyota made the cord between the power brick and the wall so short! What was their reasoning behind that? Anyway, I'm thinking of using a short (6 feet or less) extension cord so that I can plug into the wall at work without hanging the entire brick from the outlet. Any recommendations for a particular model/brand?
  2. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
  3. Edsvfr800
    Edsvfr800 Member
    67
    30
    Franklin wi
    I just use a piece of wire from a metal hanger and hook it through the small hole and hang it off an area near the outlet at work. Works fine.
  4. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    That or a bungee cord.
  5. eyespii
    48
    2013 Prius Plug-in
    Shortest extension cord with a low enough gauge I've been able to find is about 15-feet. Any recs on something between 6-10 feet?
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  7. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    Home Depot has a 6 ft. Gray 16/3 SPT-3 Appliance Cord that has 13 amp max for under $8 and they have a 9 ft. 12/3 3-Wire Appliance Cord that has 20 amp max for under $16.
    Either one works, both have right-hand connector that works great with the outlet, but the 9 ft is better.
  8. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    I use a heavy duty power strip with an on/off switch. Then I can turn it off when I unplug it.
  9. bisco
    51,154
    i use a 12' 16 gauge cord at work. it gets a little warm at the plug end, but has worked fine for the last couple months. i wouldn't worry about it.
  10. eyespii
    48
    2013 Prius Plug-in
    9 ft. 12/3 3-Wire Appliance Cord-YC-2A1/YC-2F4 at The Home Depot
    that's the one you're talking about, right?
  11. mrbigh
    3,686
    699
    Long Island, NY
    Any heavy gauge (12/3 or 10/3) appliance extension cord will do the job. Also to mention, make sure these cables have hefty connectors.
