Short in brake system after 12v battery changed
Discussion in 'Gen 2 Prius Main Forum' started by JPrius55, Dec 4, 2019.
  1. JPrius55
    JPrius55 Junior Member
    NC
    Had 12v battery changed (at auto store) and then brake system warning light came on upon driving away. Seems very coincidental. Went to dealer and they replaced ABS fuse and it immediately blew. Said I have a short in my brake system and it could cost upwards of $3000 to diagnose/fix where it is. They mentioned a harness. Prius is an 04 with just over 100,000 on it. Anyone have insight on this issue? Is it worth putting this much money into the car? Just changed drive belt and water pump. Has new tires. Other than this issue it has been a great car.
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Yea... We often call them Stealerships rather than dealerships... Their mechanics are specialists in warranty repair, not fixing older used cars. You need a hybrid mechanic that is going to find the least expensive fix. Could be as easy as a changing out a wire or sensor.
    And if it's more complex component than that the best way to go about fixing such an old car is buying a used component from a wrecking yard because the dealership will charge more than the value of the car for a new versions of complex parts.
    Try contacting @TMR-JWAP who's near you. He's an honest person who will get it fixed correctly for lowest price possible...
    SFO likes this.
  3. runxctry
    runxctry Junior Member
    24
    SoCal
    My 2006 had red triangle of death parking issues with a "parking brake not engaged" warning on the screen, when the 12V battery is depleted. It goes away once the car is started.
    Perhaps your battery is low on charge or the wrong type? (shooting in the dark here)
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Tell us about the jump start on the 12 volt battery before you went to the parts store.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Replacing the 12v battery in a Gen 2 pretty much requires disconnecting and dismounting the brake back-up power supply/capacitor box. This is the rectangular black box just to the driver-side of the battery. I would start there and look to ensure it's been properly reconnected. Inspect the wire harness to make sure none of the wires have been pinched/crushed/broken, etc.
