Short trip kills MPG?
Discussion in 'Prius c Fuel Economy' started by DKTVAV, Jul 27, 2012.
  1. DKTVAV
    DKTVAV Active Member
    510
    101
    I just got a 1.8 miles trip with a max 99.9 MPG. If I remember correctly I got the same 99.9 MPG for a 0.5 mile trip before. So I guess some short distance gets max mileage.
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    With a pre-warmed engine short trips can be great, especially when you can drive mostly EV. The trick is trying to get that kind of mpg on a cold engine and end the trip with the same SOC you started with. ;)
  3. walter Lee
    1,126
    376
    Maryland
    A short trip on purely electrical power will register as 99.9 mpg but since a Prius c HV battery is very small - your range is going to be somewhat limited unless your trip is going downhill. In addition, since the Prius c is not a plug-in hybrid the electricity used for that all-electric power trip will have to be regenerated by the gasoline engine later on - that extra load on the gasoline engine will reduce your overall (tank's) fuel efficiency. :whistle:
    Erikon likes this.
  4. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    It's a bit misleading, since you're not including the warmup period that enables EV to be used, unless you drove the whole 1.8 miles under 10mph!
  5. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    Fortunately as far as I can tell, the warm-up period where EV won't come on also pumps some charge into the battery. When I get in after work and drive off, the battery often creeps up from ~25% to ~60% in the few minutes it takes me to get out to the main road.
    HUAWEI MediaPad ? 2
