Short trip question
Discussion in 'Gen 3 Prius Fuel Economy' started by scooter4n, Mar 4, 2012.
  1. scooter4n
    scooter4n Junior Member
    27
    27
    Hello, Im new 2012 prius two owner.
    already put little over 1000mi on the car, so brake in is done.
    Question is:
    Im only 2-3 miles away from work, is it better to start car in the garage, warm it up and then drive to work.
    OR
    Start and drive right away?
    Im talking MPG here...
    I park in the garage, and it is climate controlled, so warm up even during winter is only about 2-3 minutes.
    what would you say?
    thanks all
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I would just go. You're getting 0 mpg when sitting around w/the ICE (internal combustion engine) running.
    You're going to get crap mileage w/that short a trip.
  3. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Seriously, your mpg will be bad. Not to be snarky, but think about taking a bike ride to work on nice days, or even walk.
    52,383
    don't be silly, his garage is climate controlled.:cool:
  5. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    My answer is just drive it... don't let it warm up. And I agree that mpg is not going to be good... but for when you don't have a short trip... it's great!
  6. cobradb
    cobradb Member
    105
    tn
    shortn trips mean--more frequent oil changes and the exh will not reach temps required to expel moisture which can be acidic in nature
  7. scooter4n
    27
    27
    im not planing on taking bike to work, lunch and what ever I have to do after work, LOL.
    I get about 30-35mpg doing just quick run.
    thanks all
  8. walter Lee
    1,126
    376
    Maryland
    When the Prius is in a climate controlled garage the best way to get the highest FE on a Prius is to just start it and then drive it right away. To get the highest FE possible select a route where you can limit your top speed from 25mph to 40 mph. Raise your tire pressure to 44 psi front and 42 psi rear.
  9. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    as everyone else said just drive.
    In my winter experience (parked outside) MPG drops first 5-10min then starts rising.
  10. fuzzy1
    10,602
    While awful on the overall Prius scale, this is more than double, close to triple what my Subaru could do over the same distance.
    A full warmup will probably knock your overall MPG down into the mid-upper 20s.
    BTW, I do bike to work. While averaging only one day a week over the year, it still rolls up more pedaled commute miles than your driving commute miles.
