Short warranty on replacement hybrid battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by athas17, Aug 13, 2020.
  1. athas17
    athas17 Junior Member
    Los Angeles
    2019 Prius
    My hybrid battery was replaced under warranty after 86k miles. The dealership tells me the new battery only had a warranty of 3 years starting the date they installed it. Is this true? Aren't all hybrid batteries warranted for 100k?
  2. oldtechaa
    oldtechaa Active Member
    336
    222
    NZ
    2013 Prius Alpha
    The 10year/100k warranty only applies to the hybrid drivetrain built into the car. Replacement parts can have their own warranty, which is 3 years in the case of the battery. But when's the last time you heard of an OEM battery going bad within 3 years, or even 10 for that matter? You should be good for another decade. OEM failure rates are extremely low.
    Maria Camille likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,979
    4,724
    Texas Hill Country
    In California your car's original hybrid battery warranty was 10 years or 150,000 miles, whichever comes first. So I would assume your car got a warranty replacement within ten years of delivery which probably expired in 2014 or 2015 for your 2005 car. So the warranty battery would have three years or 36,000 miles from installation, which "might" have been until 2018 (2015 plus three) depending mostly on the date they installed.
    When was it installed? Hopefully its not giving you trouble.
  4. JC91006
    16,482
    8,400
    If Toyota replaced the battery under warranty and gave you a new battery, that should last the rest of the Prius lifetime. I wouldn't even worry about a warranty at this point, especially when you have a 2005 model. Other items will break way before that replacement battery
    Raytheeagle likes this.
  5. rjparker
    7,979
    4,724
    Texas Hill Country
    It had to have been replaced at least five years ago given the factory warranty expired in 2015. She got a warranty battery at 86k. In another thread she reports the car having 126k earlier this year. My guess is she is having problems again or she would not have posted.
    #5 rjparker, Aug 13, 2020
  6. JC91006
    16,482
    8,400
    I got that she was having problems, but my point was the problems was probably related to other parts from a 2005, not the HV battery that was replaced.
    Many owners see a red triangle and associate it with a bad battery, which is what I think may be happening here
  7. athas17
    Los Angeles
    2019 Prius
    Thanks all.
    No probs with the hybrid battery. Back in 2014 when the original had to be replaced, it only had 86k on it. Pretty disappointing. So I now am wondering if this replacement battery only goes for the same mileage, I still have 30k left on it. No major probs with the car except it is thirsty for oil. I'm just thinking ahead to how long I should keep it.
