Should I avoid buying a Gen 3 Prius because of possible inverter failure?
Discussion in 'Gen 3 Prius Main Forum' started by Thirty7Degrees, May 22, 2018.
  1. Thirty7Degrees
    Thirty7Degrees New Member
    I've been interested in having a Prius be my next car, and was looking at purchasing a Gen 3 Prius to save on cost instead of purchasing a Gen 4 Prius. I have test driven both and feel that I would be happy in a Gen 3 (although I liked the Gen 4 more, but not significantly enough to pay a higher price) so no worries there. I have my eyes on a 203 Toyota Prius w/ 43k miles currently.
    However... I've been reading about the issues that a portion of the Gen 3 are having with inverter failure. Which is concerning.
    Should I avoid purchasing a Gen 3 because of this issue?
  2. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Go Honda Civic Hybrid, you won't regret it.
    51,667
    welcome!
    i don't think so. inverter failures are few and far between. unless you drive really hard.
    Thirty7Degrees and Mendel Leisk like this.
  4. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Is the problem with the inverters the IPM (Intelligent Power Module)? If so, it will likely have a 15 year/unlimited extended warranty.
  5. Mendel Leisk
    41,103
    Ignore this guy, his cornflakes have gone off I think.
    There was a recall on the inverter, basically a software update to smooth out the demand under hard acceleration. Most everyone would have done it, and any car passing through dealership, that is something they would check. You could verify with them. Also, there was a warranty extension IIRC, a goodly amount.
    I'm not worried, for what it's worth, lol.
    jerrymildred and Thirty7Degrees like this.
  6. Thirty7Degrees
    About the the Honda Civic Hybrid... I really want a vehicle that is functionally a hatchback or a liftback, which the Prius is, so another sedan isn't really on my radar at the moment. And what are the advantages of the Honda Civic over the Prius?
    Thanks so far for the answers.
  7. Mendel Leisk
    41,103
    Having had a Civic Hybrid (it's still in the family), I can think of one: it's mpg display is accurate.
    Other'n that: as you said, it's a sedan (with rear seatback that can't fold down), the hybrid battery is overtaxed and problematic (to put it politely). I still drive ours occasionally, it's around 230K kms (on second battery, also faltering), the suspension is failing, and the car overall feels like an econobox, touchy gas pedal, what can I say.
    #7 Mendel Leisk, May 23, 2018
    Raytheeagle, Merkey and jerrymildred like this.
  8. BZzap!
    BZzap! Senior Member
    1,607
    878
    With some buyers diligence, a low mileage Prius is no more of a risk than any other make. The augmented warranty on the drive components is far beyond other manufacturers offerings. With Prius reliability you shouldn’t be concerned with all the Inverter failure hype.
  9. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    You should be more worried about oil burning and headgasket failures. That's actually a common problem. Inverter problems are a possibility but not common problem at all
  10. Mendel Leisk
    41,103
    What's that car Aaron, if you don't mind? Is it a Toyota? Nice lines.
    You've probably mentioned before; excuse my flakey memory.
  11. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Corn flakey memory.
    Raytheeagle and Mendel Leisk like this.
  12. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Thank you good sir, it's a 2013 Ford Cmax hybrid SEL. Fantastic car, fast, doesn't burn oil, but damn I miss the prius MPG! :)
    m.wynn and Mendel Leisk like this.
  13. MelonPrius
    839
    516
    Nevada
    What are you getting? Fuelly shows an average of 39.3 mpg.
  14. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I'm getting 40.4 but that's almost all hilly interstate driving. Also I have some off brand non LRR tires. If I had the Michelin energy savers it came with new it would probably be around 44 from what I've gathered. My prius v was also about 40 mpg with the wrong tires. But the prius v with the right tires and right driving I could get almost 50 mpg most of the time. The biggest hit to the cmax is it can run (and will run) all electric up to 85 miles and hour. So you'll be cruising along, even on a slight uphill grade and it's full power is coming from the battery. .Well then a little bit later the battery is depleted and the engine runs under a heavy load and must charge. Charge and repeat, so hypemiling is hard. It's not the most efficient way to run a Hybrid car as all us prius drivers know. I hardly ever used all electric driving in the Prius since I knew it wasn't good for fuel economy. All that said I love my c-max, it just thinks it knows best when it doesn't ;)
  15. Prius717
    Prius717 Junior Member
    51
    Lancaster County PA
    Aaron - what made you switch from Prius to Cmax?
  16. Model 3
    Model 3 New Member
    San Francisco
    I believe this was a dealer recall. Check with the owner if his or her gen 3 was recalled.
  17. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Well my Prius v that I personally over maintained starting burning oil around 120k, and around that same time my sisters 2010 (same engine) blew its headgasket with 180k, and burning tons of oil.
    I absolutely loved that v, it being one of my favorite cars but I just decided to make the switch to the more powerful c-max. I drive a lot so I know I would have run into the headgasket issue, and probably inverter or ABS issues too.
    Thankfully the c-max has over 182k and only had one fuel injector fail a few months ago. Doesn’t burn oil either thankfully. Also love the fairly brisk acceleration.
    Prius717 and mikey_t like this.
