Should I be able to hear my HV cooling fan?
Discussion in 'Gen 2 Prius Main Forum' started by Ernie stires, Nov 6, 2022.
  1. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    My HV battery is not hot according to Dr Prius, but I have tried to hear the fan running and I cannot. Bad hearing…??
  2. Tombukt2
    Tombukt2 Senior Member
    9,235
    1,618
    Durham NC
    No generally you cannot hear it you could put a auxiliary microphone back there possibly and see what you can make happen but it works generally That's not a real heavy blowout item not much to it It doesn't run as much as your blower motor does for your AC or heat If you maintain a decent cabin temperature in the summer like with your air conditioner your fan doesn't run that much because it's nice and cool in the cabin it's getting pumped back there to wear your battery is due it's a natural flow through type system
    Ernie stires likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,483
    1,587
    NJ-USA
    Again, on the lowest couple of speeds (1 or 2), I can't hear it. Maybe by 3 if I listen for it while the car is stopped. Definitely 5 or 6 (highest).
    JahT and Ernie stires like this.
  4. highmilesgarage
    highmilesgarage Active Member
    278
    104
    Kansas City
    if you can hear your hv battery fan then something is wrong (or impending doom) with the battery. When my HV battery is bad the fan will kick in at higher speed and RTOD or Replace Hybrid Battery show up as well as the check engine.
  5. nancytheprius
    nancytheprius Active Member
    356
    152
    iowa
    ive heard mine twice. both ascending in the rocky mountains ending my 12 hour one way trips there
  6. Mendel Leisk
    38,758
    I've never heard the fan on our 3rd gen, and when monitoring with ScanGauge II was seeing speeds getting up there, speed 4 IIRC. Not sure how many "steps" it has, 5 or 6?
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Your battery is not hot because the fan runs all the time. Its running all the time in a G2 but at very low speed.
    Btw, when you get the red triangle of death and you also hear the fan running on high very clearly in the back that means the hybrid battery has failed.
