Should I buy? '06 with 54K
Discussion in 'Dealers & Pricing' started by hippopotalust, Nov 9, 2014.
  1. hippopotalust
    hippopotalust Junior Member
    Kentucky
    I'm going to be that person - I have wanted a prius for several years now, and the plan was to wait until I could afford a newer model but my current ride is not going to last that long. I commute ~500miles per week, 90% highway.
    I am looking at a '06, 54k miles, clean carfax, 1 owner, asking $10,300 (actually 10.6 - it magically jumped up $300 when i made an inquiry). Maintenance log indicates dealer maintenance about every 5k.
    I don't believe the battery has been replaced - car had not been detailed or washed when I saw it, so I doubt it had had anything else done either.
    Thoughts? Your experience is appreciated.
  2. JC91006
    16,479
    8,395
    If the mileage is real and the odometer hasn't been messed with, it could be a good buy. When your battery fails, just buy a new one at your local dealer for $2000-$2500. So under $13000, you should have a reliable car for the next few years.
  3. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    Hippopotalust – 54k-miles on a 2006 cranks out to ~6/7k-miles per year. IMHO, $10K± for a 2006 is way too much money to pay for a used Prius in Kentucky. You should be able do better. For that kind of money you should be able get a newer model year, 2007 Prius Sedan or maybe newer. KBB shows a 2006 Prius w/ 86,832 miles located in Florence, KY listed for $7,974.
    49,402
    welcome to priuschat! if it's kbb or less, sounds like a good one. all the best!(y)
  5. wjtracy
    wjtracy Senior Member
    11,323
    3,591
    Northern VA (NoVA)
    ...sounds a bit expensive....since KY is not CARB you are off warranty for the battery.
    Somehow the low miles does not always equate to the hybrid batt lasting longer.
    I guess if it's Toyota certiifed used with 1-yr warranty on batt that helps.
  6. hippopotalust
    Kentucky
    Thank you all for your input so far. And for the welcome from bisco :)
    JC - I would like to avoid buying a car with the intention of buying a new battery if at all possible. For 2.5k more I can probably get a 2010 model in the area - better idea? I plan to have the battery checked by a Toyota mechanic, but I do not know how effective that will be.
    Catgic - I cannot find that particular car on KBB. I would like to see this car if anything to use it as a bargaining tactic.
    I am aware of a listing for a 07 in Florence that the dealership claims has 34K, but the carfax says 46K and the dealership won't reply when we question the discrepancy.
    At least 2/3 of the prius' available locally have been in an accident, which I would like to avoid.
    wjtracy - it s not certified used with a 1-yr warranty on the battery as far as I know...?
  7. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    $10K seems a little steep for an 8 year old Prius even with low miles.
    But if you must have one, we understand.
  8. wjtracy
    11,323
    3,591
    Northern VA (NoVA)
    ..certified used would be from a Toyota dealer I think
  9. hippopotalust
    Kentucky
    It's not at a Toyota dealer... and if I understand the carfax correctly, it doesn't qualify for certified pre-owned (which may be why it is at the ford/ mazda dealership and not at toyota across the way!).
    It isn't at a toyota
  10. bisco
    49,402
    what is the maintenance log? toyota dealer, or owner scribbling?
  11. hippopotalust
    Kentucky
    Well, I was getting emails from the sales man even though he knew I was taking it to the mechanic on Tuesday to come take another look and 2 hours later they had sold it to someone else.
    So that decision has been made for me. May be a blessing in disguise though, I've found a very nice 2010, higher mileage, but about the same price as the asking for the '06.
