Should I call it a day? Bad invertor
Discussion in 'Gen 3 Prius Main Forum' started by vafoodie, Mar 24, 2016.
  1. vafoodie
    vafoodie Junior Member
    Yorktown, VA
    My invertor for my battery has gone bad at 117,000 on my 2010 Prius. Dealer said it would cost 3, 400 to repair. Because we have bought 5 Toyotas over the years, our salesman contacted Toyota who will pay for some of that. We'd have a 1, 400 bill left. While it has been fun to drive, I must say that this car has been the worst Toyota we have owned in terms of needing repairs. Should I trade it in and take on a car payment, or pay the $1400 and hope can make it to 200,000 + like I have with the rest of my Toyotas?
    49,500
    idk, it sounds like a lemon. what about a salvage inverter?
  3. JC91006
    16,482
    8,400
    There should be no cost to the repair, the inverter should be covered under an extended warranty by Toyota Corporate. You will find the warranty enhancement letter attached. It's good for 15 years
    #3 JC91006, Mar 24, 2016
    m.wynn and matt b. like this.
  4. DavidA
    2,328
    1,812
    Chicago western burbs
    Your dealer gave you a couple repair option$ and they didn't even mention the giant inverter recall where all dealers were told to notify and swap out inverters for n/c? You either have a naive dealer/service writer or a very unscrupulous one, if I'm reading your story correctly. 2010 models were the ones affected.
  5. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    It's possible that the inverter failed in a different way than the recall covers - but yes, draw their attention to the warranty enhancement, and ask them for the codes so you can compare against what's in the letter that was posted above.
  6. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    The recall covers applying updated software to lessen the chance that the inverter fails. Replacing the inverter is only as a last resort.
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    And a failure is not a "last resort"? ANY invertor that has been found to have failed MUST be replaced per the recall letter.
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  9. RRxing
    2,520
    1,791
    NEPA
    The quote I referenced implied that the recall replaced the inverter, which was only partially true.
  10. chronon
    chronon Active Member
    601
    105
    here and there aint be in frozen wasteland no mo..
    is this only for cali and a few other states or applies to all 50 ?
    and ...
    Toyota Prius Inverter Failure Lawsuit Moves Forward | CarComplaints.com
  11. JC91006
    16,482
    8,400
  12. chronon
    601
    105
