Should I change or flush coolant?
Discussion in 'Prius c Main Forum' started by Syed Ashar Ali, Aug 16, 2022.
  1. Syed Ashar Ali
    Syed Ashar Ali Junior Member
    83
    Houston, TX
    2014 Prius c
    Hi I have a prius c 2014 with 157,000 miles. Everything is good besides some suspension strut problems but I'll fix that soon
    My main concern is the coolant. I'm not car savvy. I even let my mechanic change the oil for me. Whenever the hood opens you can see the pink bucket container with the coolant.
    I bought the car at 49,000 miles. I've changed transmission fluid once and oil change every 5k miles. (By a mechanic of course)
    I do see the coolant level is a little bit more decreasing. Not sure if that's a concern. My mechanic said just don't touch it. But then again he doesn't work on prius cars
    So should I buy the Toyota prius c coolant from online and let a mechanic change it or should I leave it alone?
    Thanks
  2. PriusII&C
    PriusII&C Active Member
    429
    145
    San Jose, California
    IIRC the Owner's Manual says changing it at 10-years/100k-miles then average 5-years/50k-miles. Yours is overdue.
  3. ChapmanF
    18,547
    I recently noticed, in a Gen 2 thread, that what the 2008 Scheduled Maintenance Guide says about coolant is really kind of sneaky.
    So I just looked in the 2014 Prius c Warranty and Maintenance Guide, and it's sneaky just the same way!
    The charts extend to 120,000 miles and, in that whole span, the only place it outright says "replace engine/inverter coolant" is at 100,000 miles or 120 months.
    They do, however, say to "inspect" the coolant, and that comes up every 15,000 miles or 18 months.
    And every time "inspect" the coolant comes up, it is with a footnote number.
    And on every page where "inspect" the coolant comes up with footnote number, there sure enough is a matching note at the bottom of the page:
    - Refer to "Engine/Inverter Coolant" in the "Explanation of Maintenance Items" section in the back of this guide for more information.
    And sure enough, there is such a section at the back, and the first thing it says under "Engine/Inverter Coolant" is to drain and refill it. :D
  4. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Ah ok.. is the Zerex brand ok
  5. ChapmanF
    18,547
    I don't know, I tend to stick with the Toyota stuff.
    Personally, I don't end up following the chain of footnotes and changing the coolant every 18 months. I do like to dunk a test strip in it about that often, though.
    That's more like what I would mean by "inspect".
    Doug McC likes this.
  6. Doug McC
    Doug McC Senior Member
    1,081
    420
    Midwest
    2022 Prius
    I agree with ChapmanF, and I would definitely change it, as the additives that protect against corrosion are no longer able to do their job.
  7. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    Yep I've heard that old coolant can cause the head gaskets to fail and I agree with previous suggestions, ONLY use Toyota Super Long Life....it's really good stuff! (I've used them all, in non-Toyota vehicles, and I'm most impressed with how well the Toyota SLL stands up over time.)
    It is concerning that you notice the coolant level going down...might want to find a mechanic who has hybrid experience for a look over. (Might even be worth having a Toyota dealership look into it.) Better to pay a little now than a LOT later.
    Keep us posted!
  8. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Hey thanks I just got my coolant changed by toyomotors. It's a repair ship that only deals with Toyotas. Hopefully they used the Toyota brand .it was $164 after tax. Car is running smoother.
    Anything else left to change ?
    #8 Syed Ashar Ali, Aug 17, 2022
  9. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    I feel they didn't fill it ask the way or is this the level it's supposed to be?
  10. ChapmanF
    18,547
    Your photo is of the reservoir for the inverter coolant. I've never seen the Prius c's inverter reservoir up close to see where the F and L marks are. They aren't visible (to me) in your photo but you should be able to find them. If it is a little below the F mark (but still above L), that's ok, though it would have been nice to leave it at F, which might require adding, like, two ounces more coolant there.
    You didn't take a picture of the engine coolant reservoir. If a c is like a liftback, that should be near the right side of the car. How does that look?
  11. ColoradoBoo
    1,271
    879
    It's just a little below the full line...if you have a bottle of Toyota SLL you could add a bit to it. It was, probably, filled when they serviced it and a little air was left in the system which worked its way out so that would make it a bit low. If you don't have any, swing by the shop and show it to them and I'm sure they'd top it off for you.
    For folks who change their own radiator/inverter coolant in their hybrid, we are supposed to put the car in Maintenance mode and then let the engine run and top off the reservoirs while waiting for the radiator fan to come on and off two times.
  12. Doug McC
    1,081
    420
    Midwest
    2022 Prius
    On my 2022 Prius there are two lines on the bottle, marked min and max. As long as it is between those marks you should be good to go. Just keep an I on it for a few miles and don’t be surprised if it drops a little bit. If it stays too close to the min line for your comfort just ask them to top it off for you. I’d be surprised if they charged to do it but it shouldn’t be much.
    Great job on making a wise decision! :)
    edit: ditto on what Colorado said
  13. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Unfortunately I won't have time today. I'm dropping of a dylasis patient home (part time job) but if they used toyota brand can I top it off with zerex if I find it at autozone
  14. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Is this it?
  15. ChapmanF
    18,547
    No, that's the brake fluid. The engine coolant reservoir has the same pink stuff as the inverter reservoir.
    With cars, when we say "right side", we mean right side of the car (which can be your left if you are standing in front looking under the hood).
  16. Doug McC
    1,081
    420
    Midwest
    2022 Prius
    OK, I kind of hate bringing this up but at157,000 wouldn’t both the engine, and the inverter coolant be changed, along with the brake fluid (especially considering the hi humidity of the Houston area and the age of the Prius)? With the care it’s been given considering the frequency of the oil changes, the car could easily get another 157,000 on it.
  17. Merkey
    Merkey Active Member
    319
    291
    Birmingham, Michigan
    We should say...passenger side or driver side.
  18. ChapmanF
    18,547
    That actually changes more between countries.
    It is a standard convention when talking about cars that left and right mean the left and right of the car.
  19. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Yes I think the Mechanix changed the inverter coolant and engine but again I was in the waiting room with a wall in front of me.so I will never truly know
