Should I do the EV mod?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mywhitenoise, Mar 22, 2007.
  1. mywhitenoise
    mywhitenoise New Member
    210
    I was thinking $45 was kind of a waste for something that potentially voids your warranty, potentially cuts mileage, and overall looks like a hassle to install (I don't have a soldering iron, and would be a little nervous using it on my electrical system).
    However, I take the bus to work, and $45 isn't too bad of an investment since I wouldn't be using the ICE to drive to the bus stop (it's about 2 miles away). Plus its convenient if I wanted to move my car a few feet away. What do you guys think?
  2. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    In most cases, you can't travel 2 miles in EV mode. You get two mile range if your battery start off with 80% state of charge (SOC).
    I'm not too sure if this can really void the warranty, since the ICE will turn on to charge the battery if your SOC drops below 40% if you are in EV mode or not. And if you press the gas peddle down too much requiring power higher than the limit of the HV battery, ICE will turn on as well.
  3. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    I'm getting it this fall but not to run in electric mode, but to run under no propulsion at all (ie coasting). I'm an MPG phreak so I'm getting the mod to allow me to cut the engine when it doesn't need to run (ie at a stop light when the block temp is b/t 65c and 85c). Turns out this condition is most of my commute, so it suites me well. Figure it will net me another 4 mpg. Not much, but I have nothing else I can do to get those few points I want.
    If your just gonna use it to accelerate your car in EV mode rather than with the ICE, I don't know if it's worth it. Another popular reason (and one high on my list) is the ohh, ahh, wow, factor. If you have friends that would be impressed, it might be cool (if you like impressing friends).
    Just depends on what you need it for, or what you want to accomplish.
    11011011
  4. danoday
    danoday Member
    206
    Incline Village, Nevada
    I did the mod about a year ago, and can count the number of times I've used it on two hands. Most of the time, it is just to show off the ability, and to occasionally freak out someone in a parking lot by creeping up behind them.
    The mod is easy, fun to experiment with, but doesn't really seem to have much practical purpose, IMHO.
    Incidentally, doing the mod so you can turn off the ICE when idling is probably not necessary. The Prius is smart enough to know when not to run the ICE, and will turn it off automatically when going downhill or stopping at a light.
    Dan
  5. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    <div class='quotetop'>QUOTE(mywhitenoise @ Mar 22 2007, 09:38 AM) [snapback]410236[/snapback]</div>
    Hi mywhitenoise
    First, the mod is not magic. I totally agree with the others who have responded. I would add that my greatest use is for moving the car short distances without starting a cold ICE (like out of the garage for washing). You always get a more secure connection with a good solder joint and you want a good connection to the pin. (Does the kit come with the pin connected?)
    Concern about warranty would be at the time of needed repair (if that resulted from the installation). I am not aware that there is a case documented of damage leading to a warranty claim which is traced to installation of an EV switch. With the protections built in to the car (noted above), this seems very unlikely.
    My installation cost less that $5.00 (the cost of a momentary switch). The nice thing about that is that it is not necessary to touch the wiring of the car.
  6. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    Disclaimer: I'm a mileage phreak... I do unusual things to keep from burning gas.
    <div class='quotetop'>QUOTE(danoday @ Mar 22 2007, 01:56 PM) [snapback]410320[/snapback]</div>
    Most of the time yes. But in early stage operations, the ICE can take 5-10 seconds to auto-stop, and may only do so after the speedo read 0 kph for 5-10 seconds.
    I use 20oz of gas to get to work. Poor idling in early stages can make it 21oz.
    Who cares about 1oz of gas? 99.99% of drivers probably don't. See disclaimer above.
    11011011
  7. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    I got the mod last February and use it all the time.
    There's a spot in my commute when I'm commonly stopped just before cresting a hill. When traffic moves again, I'll EV just over the hill and stealth down the other side.
    Being able to shuffle the car without starting the ICE is nice.
    I will punch it just to be safe as I enter the very large parking lot here at work. That way I know the ICE will not engage.
    Sometimes the ICE wants to run at stoplights so I'll hit it then. Also, sometimes as I approach stoplights and the ICE will not shut down.
    There are other times when I use it.
    The key here is to NEVER OVERUSE IT. This will over-drain the battery and the ICE will engage to recharge and your next segment will be somewhere between 25 and dismal.
    Addressing your concerns:
    - you will not achieve 2 miles on EV. Period.
    - That I'm aware, no one has yet been denied warranty work due to an EV button.
    - Mine was installed sans soldering iron.
  8. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Allannde @ Mar 22 2007, 11:44 AM) [snapback]410352[/snapback]</div>
    Even cheaper if you're willing to give up the "Flash to Pass" part of the turn signal lever. Several owners have done that conversion.
    I have the Coastal mod and rarely use it. It's handy to move from the street to the driveway of my parent's house or around a large parking lot.
  9. Ari
    Ari New Member
    165
    I recently ordered the Sigma kit. Can anyone else who has that version say how long it takes to ship? The Sigma website says "Be aware that ordering JDM parts may take 3-5 weeks to ship" but that sounds like an awful long time! :unsure:
    EDIT: No one replied, but it takes 6 weeks door to door for the Sigma EV switch kit. Mine's arriving next week.
  10. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    <div class='quotetop'>QUOTE(mywhitenoise @ Mar 22 2007, 11:38 AM) [snapback]410236[/snapback]</div>
    I was gonna go for the mod since my job is less than 4 blocks away, but I was also worried about the warranty being voided. So I called Toyota customer care and checked with them, they said that doing this mod will void the battery warranty. The person on the phone advised that the cars in europe have a battery pack that is specifically desined to run the car in EV mode, but the US cars can't handle it, and it will lead to a premature replacement of the battery, that the warranty will not cover.
    Not worth $3,000 or whatever the price is for a new battery.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Two miles is too far. It's never going to work, unless it's two miles down a steep hill. <_<
    Tom
  12. randreed
    randreed Same as it ever was . . .
    605
    West Milford, NJ
    Yes and No . . .
    Yes - if you want to be able to show off in parking lots, etc. People DO notice the complete lack of noise.
    No - if the ONLY reason is to increase gas mileage.
  13. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(TomorrowMatters @ Mar 22 2007, 07:57 PM) [snapback]410584[/snapback]</div>
    That's a load of bollocks from everything that I've heard. If it's just 4 blocks why not ride a bike? Except in the summer. Gawd it's HOT in Pueblo in the summer! :D I was "stationed" there in 2003 and we were hitting temps of 116F out at PCD on a regular basis in July. It was, uh, "fun". <_<
  14. cireecnop1
    338
    Pueblo, CO
    I live one the East side (not the lower eastside), but thats the last thing I need is to get my @$$ kicked because I ride my bike everyday to work (State Patrol) and I work the graveyard shift so thats also another safety issue if you ask me, but I still do occasionally ride my bike, but not too often.
    It is hot down here! I hate it, but I like the town though. Oh well. If it gets too hot down here I will just run up there and hide in the shadows of the Qwest building. :lol:
  15. Fibb222
    Fibb222 New Member
    1,499
    99
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Mar 22 2007, 12:58 PM) [snapback]410368[/snapback]</div>
    I live where the winter's are mild (almost always above freezing) and I find the engine heats up shortly after takeoff. But in the first 5-10 minutes of driving, if I find that the ICE is running when I don't want it to - like when I'm coasting or stopped - I just turn off the climate controls (heat) and it stops right away. I usually just keep the heat off for the first several minutes, except in those moments when I'm using the ICE to accelerate or maintain my speed anyway. So I don't feel like an EV switch would help me much at all. I'm rarely NOT in stealth mode in parking lots anyway.
    I just wish I had a steering wheel button for fan speed/heat off.
  16. DaveG
    DaveG Member
    806
    Vancouver, BC
    <div class='quotetop'>QUOTE(TomorrowMatters @ Mar 22 2007, 05:57 PM) [snapback]410584[/snapback]</div>
    Just an FYI - Your Country/State laws may differ, but Toyota would have to prove that your EV mod did damage to the car before they'd be able to deny you warranty service because of it. Infact there is no difference that I've ever heard of before between the battery packs in Europe and North America, and there have been plenty of people who have looked at both.
    It's commonly believed that Toyota disabled EV mode in North America due to the different procedure that would be necessary for emissions testing and qualification. And possibly so fickle North American consumers wouldn't be "confused" by something so advanced and unknown as "EV mode".
    That said, I wrestled with the same dilemma myself, and eventually did the mod to my car. It's worked perfectly, although I really don't use it that much. It was more about learning about the car and doing some minor modifications - it IS after all, MY car and not Toyota's.
    At some point in the future, I'll likely trade it in for a new model and I'll remove the mod at that time (I specifically installed it to make removal easy), not because I feel there's any problem with it, but because I also don't want to confuse those same fickle consumers :p
    Dave
  17. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(DaveG @ Mar 25 2007, 12:24 PM) [snapback]411974[/snapback]</div>
    The Magnuson-Moss act is federal law. It is the same in all states (the OP lives in the U.S.).
    A Businessperson's Guide to Federal Warranty Law
  18. mywhitenoise
    210
    Well you guys had me convinced not to go with it...but like I said I take the bus, and driving only 2 miles really effects the MPG, I get something like 20-25 MPG for that short trip. Over time that's going to make an effect. There's tons of stop lights on the way there, as well.
    I was thinking about buying an engine block (I live in California, but I think this may improve the mileage because it's still cold in the morning and night) but I can't find the part. If there's a lot of stop and go in the area, and believe me you can't go 1000 feet without hitting a stop sign or light, would you recommend the EV?
  19. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    <div class='quotetop'>QUOTE(mywhitenoise @ Apr 4 2007, 10:11 AM) [snapback]417627[/snapback]</div>
    You have my $0.02, but since you brought up the block heater, here's what I'm doing.
    1) Got a scanguage so I know if my block is going to get too hot ($149).
    2) Got a block heater from Canada (PM me and I'll give you the site to order) ($50)
    3) Got an OEM EV button to kill the ICE when coasting or idling (PM me and I'll give you the site to order) ($80)
    5) Got piping insulation from Home Depot ($5)
    I'm planning on using the block heater all year so that my block temp starts at 40 oC instead of 20 oC. I'm also going to block the grill vents with the pipe insulation. I think there are 7 slits that can be blocked. I'll start out blocking 2, then 3 ... then 7. The goal is to have the starting block temp as high as possible, and the ending block temp < 95 oC. For road trips or weekend errands, I can remove the vent blocks.
    So yeah... I'd recommend the EV, EBH, SGII, and vent blocks. But again, I'm kinda nutty. See disclaimer.
    11011011
  20. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    <div class='quotetop'>QUOTE(Dan. @ Apr 4 2007, 05:24 PM) [snapback]417817[/snapback]</div>
    Wayne (FireEngineer) is coming to my home tomorrow to install my EBH (engine block heater) I'm so psyched! I am going to put it on a timer to start around 5 a.m. so that it is ready to go for me at 7:00 a.m. when I leave for work :)
    I also did the pipe insulation, I'll have him give it a good check to make sure I did a good job lol.
    I am currently averaging 54 MPG and it is still winter here... highs in the 30's and 40's.
    I am going to ask him about whether he thinks I would benefit by the EV mod , based on my terrain. His opinion will be the factor whether i install it or not.
