Should I get Prius Prime
Discussion in 'Newbie Forum' started by Alina, Jun 18, 2019.
  1. Alina
    Alina New Member
    2016 Prius c
    Technology
    Currently have a 2016 Prius C Tech (my first car.) Just got a phone call that the $500 deposit I put down for a 2020 Prius Prime is ready for pick up (I was told August.). But now I am realizing my parking spot has no electrical outlet and I cannot change it my spot. Strata will be implementing a no car charging bylaw. No option to charge at work or anywhere near home.
    I’m not a car expert and the car salesman’s is not explaining well enough to me about the Prime’s self charge capability (EV Auto?). I only drive within the city (20 km round trip to/from work) but I want the option of gas for those long distance drives and road trips.
    Should I just back out of the purchase? I didn’t sign any contract for deposit.
    Thank you so much in advance
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The Prime is a regular Prius with a larger traction battery that can be charged from a wall outlet. Once the traction battery gets down to an indicated 0%, the Prime then drives like a Prius, with a bit more battery to absorb regeneration charge. The larger battery allows the owner to drive on EV up to 30-ish miles from wall power. For the round trip drive you describe, if charged from the wall you could do the entire trip easily on EV only and not run the gasoline engine.
    If there is an outlet near your parking spot, you could run an extension cord to it. I'm not familiar with Strata - why would they implement a no car charging bylaw? Is Strata where you live, work, etc.?
    The Prime can charge the EV battery from the gasoline engine, but the mode is not EV Auto. If you press and hold the HV mode switch for a few seconds, then Charge will indicate on the dash and the gasoline engine will charge the traction battery to 80% (not 100%). However, running your engine to charge the traction battery does not improve efficiency on the commute you describe, unless perhaps you charge the battery on Monday while commuting, then on Tuesday you do the drive in EV, then on Wed drive in HV and charge the battery again.
    #2 jb in NE, Jun 18, 2019
  3. farmecologist
    farmecologist Senior Member
    1,960
    1,799
    Southern MN
    Personally, I'm waiting to see what the the 'next generation' of Prius/Prime brings us. Hopefully our current ones will hold out until then! (y)
  4. ETC(SS)
    7,359
    Here are my thoughts (FWIW)
    Economically, you're nearly always better off driving a three year old car a few more years.
    A LOT better off.
    You're basing much of your purchase decision on being able to charge a car that only has about a 25 mile EV driving range.....basically a "compliance" vehicle. Also you're nearly always better off buying cars from dealer stock rather than ordering one.
    I'm PRESUMING that you do not live in a part of Canada where block heaters are non-optional equipment, but you may not even get 25 miles of EV range in the part of Canada that you live in.
    Canadian laws are going to probably be different about deposit money for cars, contract or no contract - and your tax benefits are going to be different than each of our 50 US states as well - so you're going to have to factor all of that into whatever math formula you use to justify the decision.
    So here's how it would play out for ME:
    If the $500 is refundable, I'd only buy the Prime if it were as cheap or cheaper than the wireless (regular) Prius....and even if it were I would think very VERY seriously about just keeping the C.
    If the $500 deposit is not refundable I'd go through with the purchase, maybe, but I'd put the car under a microscope and complain about every single little mark and flaw on it and document everything BEFORE I signed for the car, and then I would become their social media nightmare.
    Many of our US states have a 'cooling off' period following car purchases, and Toyota of North America HAS to have better customer service in Canada than they do in the US, so you may get some relief there as well.
    ---all of this is presuming that you signed nothing when you put down the $500 deposit - which is also very curious.
    I'm thinking I read that they're going to stuff a 5th seat somewhere in the 2020 Prime.
    This wouldn't normally be very interesting to someone who drives a C-type...unless you're family situation is changing, BUT one presumes that three years from now a gently used Prius with 5 seat belts will be worth more than gently used Priuses with 4 - beyond the extra year's depreciation.
    Your call.
  5. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    You have already answered your question. You have no way to charge the car either at home or at work. Get your deposit back, unless, you were getting the car for a carpool sticker. Then it’s your call.
  6. PriusCamper
    PriusCamper Senior Member
    13,075
    5,306
    Pacific Northwest, USA
    I don't know what Strata is but if that's some kind of homeowner's or neighborhood association or using a bylaw to prevent car charging you need to expose them and get people to let them know as often as possible that they're moving out, or canceling their plans to move in due to anti-climate hate/discrimination. I'd also get a lawyer to look thru your basic rights, contracts, agreements that were signed and then write a letter, that will make them have to hire a lawyer to respond. That's the kind of pressure it will take. Similarly in Canada when they rescinded tax credits for Tesla buyers, Elon sent a pack of Lawyers after them and the greedy evil-doers of fossil fuel dominance backed down right away!
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    In the US, rebates and incentives would be by state, I have not lived in Canada since 1987, so I am not up on rebates by Province.
    Since you do not list a province everyone is going to be very generic.
    Canadian gov’t outlines EV incentive details, list of 27 eligible models and trims | Driving
    Electric car incentives in Canada — what to know about the rebate that includes Tesla 3 - National | Globalnews.ca
    "The federal rebate works in addition to any provincial zero-emissions vehicles incentive, which is currently only in British Columbia and Quebec."
    #7 JimboPalmer, Jun 18, 2019
  8. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    This is a bit of a stretch.
  9. PriusCamper
    13,075
    5,306
    Perhaps... But banning plugins use for plugin cars is wrong-headed and anti-progressive and about as dumb as banning people from buying plane tickets online and forcing them to only buy through a local travel agent. It's so far behind the times that the reaction people will have will keep getting worse and worse and if they don't back down there's gonna be lots of name calling and wild accusations... And I'm eager for it to get to that point!!! :)
  10. Skibob
    2,912
    1,505
    Northern California
    The banning plugins thing is probably more about people stealing the electricity from a common plug than anything else. I would guess people are free to have their own charging station or plug in their own garage where they pay for electricity.
  11. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    Skibob likes this.
  12. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    It appears that the association does not want to fund charging stations for use of a few members. That sounds reasonable. The few members should fund their own charging.
    Skibob likes this.
  13. PriusCamper
    13,075
    5,306
    There's a big difference between funding full blown charging stations vs. banning people from running an extension cord to their car... The former is a major accommodation, the latter is no more than letting them do it, or at most having a maintenance guy add an extra exterior outlet so the extension cord doesn't have to be so long.
    But as is so often the case here the new person posting didn't give enough details and we don't even know who/what a "Strata" is... So the conversation is heading towards a waste of time real fast, as is so often the case here.
  14. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    In the reply above you will see it is a Canadian association similar to a condominium.
  15. Skibob
    2,912
    1,505
    Northern California
    Umm no. The person would be stealing electricity from the common account all the residents pay for. Why should everyone have to pay for someone’s gas savings. 100% right to ban plugins in that situation.
  16. Salamander_King
    11,024
    8,970
    New England
    Strata Housing - Province of British Columbia
    I believe "Strata" is the type of a housing option available in B.C., but not knowing where the OP is located in Canada, it may not. Who knows. Yeah, without OP providing more info, it's only speculation.
    In any case, if OP has no way to charge the car, and PRIME does not provide substantial incentive over regular Prius, I would get the deposit back.
    #16 Salamander_King, Jun 18, 2019
    jb in NE and Skibob like this.
  17. bisco
    52,396
    yes, you should back out of the deal. prime would be a costly mistake for you. stick with your c
  18. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
  19. thefranchise713
    thefranchise713 Junior Member
    75
    52
    Buffalo, NY
    2018 Prius Prime
    Believe it or not, that argument tends to find some weakness when you realize what condo associations often share collectively. In my own, we have shared water, garbage, and garage electricity (although the circuit is too small to put on much more than lights and door openers.) Of course, we also have snow removal, lawn care, and other maintenance--but these are more evenly spread out than the former resources.
    Some people have whole families in these units, and I'm a single guy--I pay the same rate even though I use considerably less of each resource. I'm not terribly worried about the "communal" price of electricity, especially when we're at a low rate in NY per KWH in my region.
    I raised the charging issue here, but right now it's not on anyone's mind enough to care. You pick your battles, and I bought the Prius Prime realizing I'd almost certainly have to drive it as a normal hybrid. And considering I got it nearly 11k off and cheaper than a normal Prius, not regretting that decision.
  20. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Even if you lower your Prime charge current to 8 amps?
