Should I have pressure on brake pedal?
Discussion in 'Gen 2 Prius Main Forum' started by Bronze84, Nov 6, 2013.
  1. Bronze84
    Bronze84 Member
    118
    25
    South Derbyshire
    Hi guys
    Would like to get some info regarding the brake pedal on my Prius.
    When it is completely turned off the brake pedal doesn't build any pressure. In previous cars I have had the brake pedal would build pressure and then release that pressure when the ignition was started. My pedal only has ever so slight pressure and is able to go all the way down to the pedal stop.
    Is this normal or could it be something wrong?
    I have a Toyota Warranty until Jan 2014 so was thinking about taking it in for a free health check. If there was something wrong with my brakes then it'd get done under warranty before it runs out
    Cheers chaps
    Turn off signatures in Tapatalk Tapatalk
  2. hlunde
    hlunde Member
    419
    75
    What you describe is a characteristic of a vacuum brake booster which is not used in a Prius. Prius uses a gas- charged hydraulic accumulator -- which was the subject of the early-production GenIII recall.
    Bronze84 likes this.
  3. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Hi Martin, This is normal for the Prius as it has a brake pedal stroke simulator effectively built on top of the hydraulic brakes. This is so that the pedal feels like a normal hydraulic pedal while you are using regen braking.
    As well as this the Prius does not use vacuum "servo" assist brakes as the engine does not run all the time. It uses an electric fluid pump that pushes fluid into a pressure bottle. This pressure is released to give a servo effect when using the hydraulic brakes.
    John (Britprius)
    Data Daedalus and Bronze84 like this.
  4. Britprius
    5,194
    1,918
    Martin, check this out. The brake circuit (hydraulic) for the Prius.
    John (Britprius)
  5. bisco
    51,155
    when i open the drivers door, the brake accumulator kicks in. by the time i sit and put my foot on the brake, it feels normal. yours should too.
  6. Bronze84
    Bronze84 Member
    118
    25
    South Derbyshire
    Chaps, as always many thanks for the replies and the reassurance. Panic over! Lol! I may just take it for a health check anyway as my warranty is running out so would be a good way of finding any potential issues and getting them done under warranty, what do you guys reckon?!
  7. bisco
    51,155
    probably a good idea, how many miles on her and what is your warranty?
  8. Bronze84
    Bronze84 Member
    118
    25
    South Derbyshire
    74k miles. And it's a full 1yr Toyota dealer warranty
    Britprius likes this.
