Should I have these service items done?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Freedom, Apr 17, 2015.
  1. Freedom
    Freedom Active Member
    535
    69
    Northeastern MA
    Carmine was in for an oil and filter change 2 days back. As usual, the Tech comes out to me with a laundry list of things he "says" need doing. For some strange reason, I do not trust my Toyota dealer Service dept. :cautious: So I tell them to write it all down and I will think on it. Then I come here to check!
    Carmine is a 2008, with 53633 miles total. Here is what they recommend:
    Brake Fluid Service $130
    Transmission Drain and Fill $185
    Clean and Adjust Brakes $60
    I did look at this thread: What services you need and what you don't | PriusChat From that, I conclude that I am overdue for the last item -- Clean and Adjust Brakes. And I do not need either of the other 2 items at this time.
    Agree? Disagree? Did I misread the thread above about services you need? Thank you!! ;)
  2. JC91006
    16,496
    8,406
    Those are some really high labor rates. I would actually do the transaxle fluid service. The brake fluid is good for 100k miles or more. The clean brake thing.....unless you have braking issues, you can skip this. Most of the Prius braking is electronic, it doesn't use the pads unless you're going under 7mph.
    Transaxle fluid change here at an independant shop runs around $60-$80. Dealerships here might charge $120 or so.
  3. Freedom
    535
    69
    Northeastern MA
    I wasn't sure if "transmission" (my shop quote) and "transaxle" (the service thread I linked to above) were the same thing; the lady in the parts dept told me no they are different?
    Yes, pricing here in RI is very high on most everything.
  4. Yakoma
    Yakoma Active Member
    470
    124
    ATL-ish
    I think the lady in the parts dept doesn't know what she's talking about. But if they think they are different, then I have no idea what transmission fluid they're changing if it's not the transaxle.
    I agree with JC above. You can get the transaxle fluid change done for less I hope. Personally I'd do it myself, but you may not have the tools or the inclination. Skip the rest.
    I'm curious what kind of brake cleaning/adjusting they would do for $60. My guess is they would look at the brakes (maybe with the wheels on the car) and perhaps spray some brake cleaner on them. Done. Can't imagine they would remove the wheels and do any brake disassembly whatsoever at that rate.
  5. bisco
    49,733
    my daughter has my old '08 with higher mileage than yours. i wouldn't do any of those unless you are keeping the car longer than 150k. in that case, i'd do the tranny oil, but shop for $120. or so. it's easy diy, so maybe ask a local mech.
  6. Mendel Leisk
    38,898
    That's something worth doing tri-yearly, regardless of mileage. Toyota is coming around on this now. And the price is not bad, a little high, but Prius brake bleed is tricky. If the pros want to do it for that amount, I'd say go for it. Do ask them if they're going to road test it after. Be very specific, make sure they're on their best behaviour. It is possible to screw up the brakes when bleeding them.
    Good idea with your mileage, I'd do it a fair bit sooner, for a first time, which tends to be the worst. The price is a bit steep. I've done DIY on ours a couple of time now, the fluid and a couple of drain washers come in under $40. And it's an hour's labour, at most, very simple for them with hoist. Up here dealerships were offering the service for $79.95 (Can), which is quite good. $100 would be my ceiling.
    Meh, don't know know about that. $60 is cheap, really cheap, but what are they doing for that. A proper brake job, front or back, would be around $150. I'd ask for more details. It is worthwhile to do a proper inspection, say bi-yearly. Remove the caliper, pull out the caliper pins and relube, check pad thickness, clean and re-install (or replace as needed). Inspect rotor, check runout and parallelism. But you're not gonna get that for $60.
    And the rears are drums? Check shoe thickness, put a little fresh anti-seize compound on the contact points between shoe and backer plate. That's about it. Sometimes just getting the drum off can be the main event, tho.
    Brake inspection IS in the scheduled maintenance, you knew that right? ;)
  7. ETC(SS)
    6,585
    The I wouldn't let them touch my car!
    Will they 'fess up if they mess up?
    Would you trust them to make things right if they break something while they're fumbledoinking around with your car?
    If you stay with the dealer:
    Ask them to point to each of these items in the MAINTENANCE SCHEDULE (that came with YOUR car) and justify the expenses.
    Actually, the Transmission fluid replacement is not stupidly high (if they do it right) but I'd want to know a little more about what a brake fluid service actually entails and why it's necessary.
    If you hear the word 'hygroscopic' in their explanations redouble your suspicions.
    I'd also be curious what "adjustments" are required on your brakes that mine have not required for 80,000 miles.
    Offer them $120 fro the transmission flush
    and get back with us on the justification for the brake work.
    Although not on your maintenance schedule, this is recommended by many Prius drivers on this forum.
    Good Luck.
  8. Mendel Leisk
    38,898
    ETC, I don't mean to be stepping on your heels all day, but brake inspections are in the schedule.
  9. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    I agree with Mendel.
    Given the age, none of those recommendations are really out of line.
    Could you skip it and just keep driving ?
    Maybe; probably.
    If money REALLY is a problem, maybe you should skip everything but the brakes.
    Otherwise I'd get the stuff done.
  10. ETC(SS)
    6,585
    No sweat.
    That's why I have two of them.
    Hey.....I fix phones for a living ;)
    I'm good at offering advice.
    Sometimes?
    It's good advice. :D
    Have a good weekend!
  11. Freedom
    535
    69
    Northeastern MA
    Mileage wise I have no idea; I do not plan to buy another car in this lifetime.
    OK sounds like none of this is immediate. I am moving May 4th so time is more of an issue just now than the $$. Then I will be in another state, new dealer etc. and can see about getting things lined up.
    I do not understand why the transmission fluid is fine until 100k miles (per that service link) but many here are suggesting I do it at half that mileage.
    The brakes, well, they do this 21 point inspection, brakes are marked OK, parking brake is marked poor. Considering the only 3 or 4 times I used it I forgot and drove a short distance down the street trying to figure out why the car was so sluggish and "oh yeah, parking brake!" Well, yeah, I can see why that came up poor. After I kept forgetting it, I just stopped using it.
    Partly, that is just my nature. Partly, that is because when I bought Carmine new in 2008, even most Toyota dealers didn't know how to service a Prius. Remember when they kept putting in the full 4 quarts of oil instead of 3.5? Yeah, I DO. So now, I ALWAYS tell them; by now I'd hope they know, but it has become routine for me to say that when I hand over the key fob. That, and asking on here about everything they want to do, those are my 2 standards.
  12. bisco
    49,733
    actually, toyota considers the tranny fluid to be lifetime. some here have had it tested early on, and the recommendation came back to change it if you are keeping the car long term. what is long term? there's the rub.
    and btw? some of them still put in 4 quarts.:p
    p.s., i hope you're moving somewhere warm!(y)
  13. Freedom
    535
    69
    Northeastern MA
    For Gen II? I thought that was a change for the later versions. OK thanks.
  14. bisco
    49,733
    pleasure.
  15. Yakoma
    470
    124
    ATL-ish
    Given the cost/benefit analysis of changing the transmission fluid - especially if you do it yourself - it's a no-brainer. I did mine at 80K. It was not filthy but it was not fresh. There were small filings and some minor sludge on the drain plug. I'm glad I did it and plan to do it again at another 50K. It's not that expensive and it's simple to do.
  16. Freedom
    535
    69
    Northeastern MA
    I will investigate doing this as a DIY AFTER I have the move behind me. Only so much I can tackle at one time, being it is just me, myself and I. Girl Power! I will watch some online vids to see what is involved -- AFTER I have moved.
