Should I have Toyota check my battery under warranty?
Discussion in 'Gen 2 Prius Main Forum' started by docproteus, Aug 5, 2018.
  1. docproteus
    docproteus Junior Member
    43
    Ct
    Just bought a 2007 with 147,000 miles on it. After about 2000 miles I'm averaging 43mpg when my previous 2007 (I sold it to a friend) was averaging about 47/48. I know a lot can have to do with tires and beyond but i'm wondering if I should have Toyota check the batt under warranty. I'm guessing there is a healthy charge so my questions are as follows.
    1. Is there any concrete way I can figure out the health of my battery myself?
    2. Is there a concrete way that they actually check and can figure it out or are they essentially looking at anecdotal evidence?
    150K is around the corner and I'm in a CARB state so it's now or never. Thoughts?
    nssdiver likes this.
  2. nssdiver
    nssdiver Me digging' life
    Syracuse, NY
    Four Touring
    Do you have a quote for a check? I don’t see a dealer doing one for free. If you don’t have a check engine light on, or are failing emissions, my dealer would tell me that the car is performing within expectation. Or something along those lines.
    iPhone ?
    dubit likes this.
  3. docproteus
    43
    Ct
    Kind of what I was thinking. Like I said, wasn't sure if there was some divining rod they held out ofver the car that turned when the batt was no good
  4. nssdiver
    Syracuse, NY
    Four Touring
    Google the OBD2 reader that will tell you individual pack voltages. IMHO, that will put you farther ahead probably both $$ wise as well as info wise. Plus, you can use the reader down the road.
    Monitoring your pack voltages over time will probably be the best thing you can do.
    iPhone ?
  5. docproteus
    43
    Ct
    Interesting. So that will show me what each cell is reading? Is it fairly straightforward and do I need a pc to connect it to or is it complete? Finally, it looks like there are a lot of different ones with vast price diffs. Any thoughts?
  6. bisco
    49,586
    it's 10/150, whichever comes first...
    wjtracy likes this.
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,375
    3,229
    Madison, Wisconsin
    Yeah. I was a bit confuse.
    10 years from 2007 is 2017.
    Isn't your warranty expired already?
    Unless you managed to buy a new 2007 in mid 2008?
    wjtracy likes this.
  8. nssdiver
    Syracuse, NY
    Four Touring
    I believe this is what a bunch of PriusChat people like:
    Gen2 Prius: Custom PIDs for Torque (Android App) with formulas | PriusChat
    The Prius throws codes sometimes that don’t match what other cars throw. (Happened to me once.)
    iPhone ?
  9. wjtracy
    wjtracy Senior Member
    11,327
    3,593
    Northern VA (NoVA)
    Doc per above you are probably out of CARB warranty due to over 10 years since first purchase. Not to mention we are assuming it was orig purchased in a CARB state.
  10. bisco
    49,586
    maybe the extended warranty purchase, 15 years?
