Should I leave the Prime plugged in when not in use and charge is complete?
Discussion in 'Prime Plug-in Charging' started by rmnelson, Dec 6, 2016.
  1. rmnelson
    rmnelson Junior Member
    Eugene, OR
    Pretty much covers it; I'm not driving every day and just wondered what the correct procedure is. Can't find
    anything in the manual.
    priuscatprimeguy likes this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    yup, it's ok, I had a 2012 PIP and then a 2015 PIP left them both plugged in after full charge and had no issues. You can even pull the plug before charging is complete.:cool:
    48,947
    no problem, it shuts down when done charging and nothing happens after that. question, does the o/m warn against leaving the battery fully charged for long periods of time?
  4. priuscatprimeguy
    2,730
    2,640
  5. bisco
    48,947
    i read the pip manual on a cali flight, looks like prime would require flying back to the homeland.
    page 133) leave a low level of charge in the hybrid battery when leaving the vehicle undriven for a long period of time.
    use the charging timer function as much as possible in order to fully charge the hybrid battery immediately before starting off.
    #5 bisco, Dec 6, 2016
    Insirt and priuscatprimeguy like this.
  6. rmnelson
    Eugene, OR
    I couldn't find leaving it plugged in addressed in either the pdf or the printed manual.
    Tesla S manual goes on and on about how wonderful it is to leave it plugged in when it is not actually moving down the road. Keeps the battery topped up and lets you precondition whenever you want. I was surprised to not find a single word about this in the Prime handbook; perhaps better referred to as the two hands book. 800 pages? Come on. Big jet airplanes don't have that much. It's certainly more than my attention span can handle.
    #6 rmnelson, Dec 6, 2016
  7. bisco
    48,947
    what about the advice on page 133?
    #7 bisco, Dec 7, 2016
  8. priuscatprimeguy
    2,730
    2,640
  9. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    My girlfriend tells me not to pull the plug early. Not sure who to believe now.
    priuscatprimeguy, krnkoala and bisco like this.
  10. bisco
    48,947
    it's kind of ambiguous, but it is what it is. tesla chemistry must be different if they tell you to leave the battery full and plugged in all the time. it would be interesting to know what leaf, volt, bolt, ionique all recommend.
  11. Trollbait
    11,319
    In the case of Tesla, it is because vampiric draws, one of which is maintaining the 12volt battery. If not plugged in for an extended period of time, the battery will brick. The amount of above buffer in a Tesla pack is likely more than what others have; 'fully' charging the pack past the regular limit for a long trip is an option on a Tesla, but they warn against doing so regularly. So there is less risk in keeping it charged.
    Any Li-ion can brick if the charge gets too low. Keeping them fully charged all the time is also bad. 80% SOC is where the are happiest long term. That is probably where Tesla has the SOC at with normal charging. Those warning against keeping the car fully charged are likely going to a higher SOC that has more risk for storing the battery.
  12. bisco
    48,947
    you think pip and prime have higher state of charge than others when full? both manuals recommend driving ev until engine comes on before storing.
  13. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    I've come to unplug as it's not uncommon for the electric power to cycle on and off at the house, usually due to wind, storms, squirrels having a play date on the transformer or a vehicle into a pole. When that happens, the vehicle will start a new charge cycle and keep emailing until the power stops fluctuating.
    Will also unplug if bad storms are on the way or forecast. We've had ef-1 tornadoes touch down within 5 miles of the house in years past, and also get frequent lightning, which interrupts power.
    Here's a neat map of lightning strikes in the U.S.
    fwiw, we have whole house surge protection on the main breaker panel.
    MMBH likes this.
  14. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Hard to find a manufacturer more conservative than Toyota in this respect.
    If it is for maintaining the 12V only without additional substantial parasitic drains, I think it will take several months to brick a full Tesla traction battery.
    #14 giora, Dec 7, 2016
  15. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I always thought those manufacturers who recommended not leaving a lithium battery fully charged did so because if "something" happens, there is less energy to deal with.
  16. bisco
    48,947
    that's an interesting take.
  17. Trollbait
    11,319
    A PHEV will have more charge than a BEV when 'empty' for hybrid operation, but that sounds risky. Guess it depends on what they mean by storing.
    I didn't consider that they were air cooled before. The charge of the battery increases as it warms up. Relying on ambient air temperature alone could mean a charged pack could have its SOC rise into the damaging zone if left in, say, an Arizona garage during the day.
    Roadsters bricking batteries became news because of collectors that stuck the car in a storage unit without being plugged in. So it does take months, but with the over the air updates and monitoring, there is more losses than with other BEVs.
    Without the system in power saving mode, a Tesla can lose a noticable amount of range sitting unplugged for a week. A Leaf in the same situation won't lose as much range, but it doesn't have all the parasitic drains; one of which is maintaining the 12 volt. So a Leaf may not lose range, but it may not start because the 12volt is dead.
  18. bisco
    48,947
    agreed, that's the problem with their ambiguous wording.
  19. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    After depleting the hybrid portion of the battery, the PiP still has 17% SOC lower buffer, that is considerably more than any modern BEV so what exactly sounds risky?
  20. Trollbait
    11,319
    Well, the fact that all batteries will self discharge, so a Li-ion bricking is just a matter of time. Then combine that with Toyota's recommendation to not charge the pack before storing the car without defining what they mean by storing. Are they talking about a couple weeks while the person is on a long vacation, or of the car being parked for 6 months or more.
