Should I preemptively change out the inverter pump?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Matt98svt, Sep 17, 2023.
  1. Matt98svt
    Matt98svt Junior Member
    81
    South Carolina
    2015 Prius v wagon
    2013V with 188k. I have cleaned the EGR/intake manifold, replaced plugs/ water pump/pvc valve/coolant etc but should I swap out the inverter pump as well just to be safe? How long does these pumps tend to last and how difficult of a job is it? I received a thing in the mail from toyota about a extended warranty on the inverter itself but was unsure if these failures were due to the pump failing first. If the pump fails does the inverter fail shortly after? Thanks in advance
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,503
    6,591
    Texas Hill Country
    The inverters fail due to weak transistors. The risk is you get a counterfeit pump.
    Matt98svt likes this.
  3. Mendel Leisk
    41,896
    Not sure about inverter coolant pump, maybe, but engine coolant pumps have been failure prone, and preemptive replacement has been recommended (by a few members here), say by 150k miles.
