Should I Upgrade Suspension when going PHEV?
Discussion in 'Prius PHEV Plug-In Modifications' started by pjo180, Oct 15, 2011.
  1. pjo180
    pjo180 Junior Member
    38
    I am planning to get a Hymotion Plug in Conversion on my '08 Prius soon. Any thoughts on whether or not I should upgrade the suspension? Would upgrading the suspension increase the car's load capacity, compensating for the weight of the new equipment, or just improve handling? Seems like I remember reading that even though the conversion adds about 200 pounds, it is effectively more like adding 300 lbs. Anyone else see, or understand that?
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    38
    Santa Fe, NM
    It will have a significant effect on rear ride height. That's probably what is meant by 200lbs feels more like 300. Several people have had custom springs made. Commercial spring kits are all of the lowering type. I am not aware of any over-the-counter drop in replacement springs that maintain stock ride height in light of increased trunk load, or air adjustable shocks -- but I would be very happy if someone would correct my ignorance!
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
  4. seilerts
    3,326
    1,519
    38
    Santa Fe, NM
    Manufacturer? Part number? Please??? Note, 2004-2009 is different from 2010+
  5. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    These folks have upgraded springs and shocks specifically designed for
    the additional weight of the Hymotion conversion:
    Green Car Clinic
    At $899, the price seems "a little high." :eek:
  6. seilerts
    3,326
    1,519
    38
    Santa Fe, NM
    That's with installation, about 3 hours labor, and includes a new pair of KYBs. Pretty fair if you ask me. Perhaps with enough interest they can be persuaded to sell the springs by themselves.
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,350
    Madison, Wisconsin
    Here is another option. I'm cut/pasting from what I wrote in another forum:
    Here's a video about replacement springs in Prius that has a PHEV
    You can buy the springs through Carolyn at Luscious Garage in California for $300 plus shipping.
    475 9th Street
    San Francisco, CA 94103
    415.875.9030
    Luscious Garage | Hybrid Specialists
    She and her shop are great assets to the hybrid and PHEV community, so if you can buy them through her, it will be money well spent!
  8. scottsim
    scottsim New Member
    78
    I have the bigger springs and the stiffer torsion plate, but have been told that a steering stabilizer will restore my (10Kwh PIS conversion) handling to closer to normal...I guess Luscious could do that as well/
    Scott
  9. sub3marathonman
    sub3marathonman Active Member
    557
    75
    I have the Hymotion kit in my Prius, and I think, at least in my situation, an upgrade is completely unnecessary.
    The Hymotion kit reduces the load capacity of the Prius by 200 lbs. If you measure 200 lbs in the trunk, that dropped the rear bumper by 1 inch. Now, I've taken the spare tire out, which was 25 lbs. And it is now going much farther with less gasoline in the tank. You could only fill it halfway, and reduce the weight in the back by another 40 lbs or so. I would say the difference now is about ½" which is really not noticeable.
    Now, if you're carrying four adults regularly in the car, you might be approaching the weight limit. But I don't think even adding heavy-duty rear springs will increase the weight limit rating.
  10. seilerts
    3,326
    1,519
    38
    Santa Fe, NM
    The main issue is clearance over speed bumps and driveway entrances. It is definitely a problem with 4 people in the car and PHEV in the trunk. Unfortunately, not all of us are in sub-3 marathon shape!
  11. pjo180
    38
    Thanks for your perspective sub3marathonman. I had not thought much about the weight of a full tank of gas. Anyone know how much a full tank adds in weight? What about realigning the head lights after one of these installations? Did you feel the need to do so?
  12. seilerts
    3,326
    1,519
    38
    Santa Fe, NM
    If you have HID headlights, they are self-leveling. A full tank of gas weighs about 80 lbs.
  13. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    You can now buy the raising springs (500 pounds) for a Prius PHEV conversion on Ebay:
    http://www.ebay.com/itm/Heavy-Batteries-Toyota-Prius-Rear-Springs-500-Pounds-Extra-Payload-Capacity-/320805070717?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4ab178e77d
    500 pounds = 226.796185 kilograms
    226 kg is about the weight of a 8KWH Enginer PHEV kit.
    USA deliveries only. US$375 free delivery.
    I was quoted by my local suspension dealer in Australia http://www.wholesalesuspension.com.au/ AU$195 for custom made rear springs for my Prius to raise the rear to same as front. AU$385 fitted.
  14. Flying White Dutchman
    4,376
    313
    there are also so called rubber coil boosters
    and lots of other names for it
    it are rubber pieces that you put in between the windings of the spring coil
    its cheap and seems to work
    i wil do this anyway
    edit
    a example
  15. lopezjm2001
    1,146
    407
    Sydney Australia
    Rubber coil boosters are made by the Dodgy brothers. There have been instances where they have been chewed up by the springs. On one occasion they fell out of the springs whilst going over a speed hump. They are cheap and are not made to last.
    Even using spring spacers for the same effect. I have yet to find spring spacers specifically made for a Prius to carry a specified weight.
    Any professional working in the suspension industry would not use them.
  16. Flying White Dutchman
    4,376
    313
    dodgy brothers? can't seem to find that brand
    I keep ending up at GM with every google search
  17. seilerts
    3,326
    1,519
    38
    Santa Fe, NM
    I tried the rubber spacers for a while, as an emergency stopgap. Now that springs are readily available, there is no question in my mind that I would buy them. If you are putting thousands in for batteries etc, don't cheap out on the suspension.
  18. Mr-plugin
    Mr-plugin Member
    98
    51
    Sandy,UT
    I picked up my springs from Valley Springs In California. Was about $270 shipped.
  19. lopezjm2001
    1,146
    407
    Sydney Australia
    My suspension supplier www.wholesalesuspension.com.au has quoted me AU$195 for custom made rear coil springs. AU$385 fitted. There is a place in Townsville which manufactures coil springs just for Prius taxis. There are many Prius taxis in Townsville, Queensland Australia. They told me that I just need to specify the extra weight for the springs (225kg) I need and they will make them. They also told me that the wheels need reallignment after the heavier springs have been installed. Will take two weeks to make. I have ordered mine.
  20. Braddles.au
    Braddles.au DEFAnitely using an EBH
    295
    99
    Canberra, Australia
    And that's a good thing. "The Dodgy Brothers" was a long-running joke on the Australian comedy shows "Australia, You're Standing in it" and "Fast Forward". The Dodgy Brothers wore ill-fitting suits in vertigo-inducing fabrics while spruiking poor-quality products and services. "Dodgy Brothers" means something of dubious origin or quality.
