Should the “Cooling Performance of the Hybrid Battery is Low” warning stay on after cleaning?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rich Fife, Aug 21, 2024 at 12:43 PM.
  1. Rich Fife
    Rich Fife New Member
    Today
    My wife's 2015 Prius threw this warning about a week ago and I removed about 1/4 inch of lint from the filter. She doesn't drive much.
    Does that warning go off by itself? Can/should I clear it with tech stream? How long does it take?
  2. Mendel Leisk
    38,865
    Did you clean the fan and the ductwork leading to it? If you had that much link on the inlet filter, the rest is likely pretty snowed in as well.
    See video 21 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    But do take a look at this first:
    HV Battery Fan Cleaning | PriusChat
    ^ in a nutshell: no need to remove rear seat.
    Also, you CAN clean the fan without removing it; just getting down to it, but leaving it plugged in and bolted down, you can clean it fine say with Q-Tips. Don't make more work for yourself.
    #2 Mendel Leisk, Aug 21, 2024 at 4:29 PM
