Should you have your oil changed by a dealership?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Templeton, Mar 14, 2026.
  1. Templeton
    Templeton Active Member
    332
    118
    usa
    2024 Prius Prime
    SE
    Umm, I think perhaps not:
    (one of many, many, many true stories of dealer incompetence, fraud, and worse; make a nice bowl of popcorn and enjoy :))
    2023p likes this.
  2. soft_r
    soft_r Active Member
    190
    157
    Beverly Hills
    2024 Prius
    TLDW - Dealership lube jockey messes up with the oil filter housing, starving the engine of oil. Dealership says not our problem, dumb customer goes to a repair shop and they parts canon the engine and didn't fix the actual issue.
    Customer should've sued the dealership from the start.
    Smart techs don't work at dealerships, they know better money is elsewhere. When you go to a dealership just keep in mind that the person doing diag and working on your car is going to be someone who is too stupid to move to a better place because they lack the foresight or the skills to.
    52,436
    I got the two free ones and moved on.
    And I always check the level before leaving
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,279
    887
    Monument, Colorado USA
    I was near the automotive department of my Walmart (they, also, have a service center)
    They had a sign HELP WANTED so I asked where the lube guys went....they told me our local Toyota dealer just hired two of them!
    Oh, this is the SAME Walmart where the "mechanics" accidently forgot to replenish oil when doing an oil change on not one but TWO vehicles, burning out the engines.
  5. BiomedO1
    BiomedO1 Senior Member
    4,274
    2,238
    Left Coast
    Just what the dealership was looking for; EXPERIENCED SCREW-UPS...:(:LOL::ROFLMAO:(y) :whistle:
  6. Templeton
    332
    118
    usa
    2024 Prius Prime
    SE
    You're a braver guy than me ! ;)
    Prodigyplace and bisco like this.
  7. bisco
    52,436
    I haven’t had any trouble since they first instituted the free program, but I always checked the level and it was usually overfilled
  8. Prodigyplace
    12,690
    11,834
    Central Virginia
    How di you know they changed the oil & filter? Do they offer the old stuff back?
    My local dealer does not even adjust tire pressures to numbers handwritten by the tech. I would not trust my local dealer to do the job or do it properly.
  9. bisco
    52,436
    Only when they overfill it. Or maybe they just add a little to make it look good :cool:
  10. Prodigyplace
    12,690
    11,834
    Central Virginia
    And Toyota vs Lexus is not a problem. They use the same parts and part numbers for most things.
  11. Mendel Leisk
    41,969
    One reason they may overfill, at least my personal DIY experience: if I do a good drain, (leave everything dripping, go have a cuppa), then refill with the spec'd amount of oil, get the front back down, run it a minute, wait 5, and then check, it's invariably a little low, maybe 1/2" below top mark (equates to about 1/2 quart/liter).
    I know from experience, to wait, leave it thus a few days, then recheck. Doing that, I find the level's only about 1/8" below the top mark, and that could maybe be chalked up to DIY technique, having the front-only raised, quite high, which with the oil pan's drain bolt's aft edge of oil pan location, could afford a more efficient drain.
    Dealerships or other pro's don't have that luxury, want to see the oil right at the top mark, before they hand it back. So maybe makes for a modest overfill.
    Another annoyance is the permanent housing style oil filter on the 3rd gen (and early gen 4 years as well): it too easy to screw up, for pros and DIY alike. I've caught myself at least once, starting to put the housing back on, sans filter. Pros should not, but...
    #11 Mendel Leisk, Mar 16, 2026
    Eddie F, Prodigyplace and Templeton like this.
