Should you tie down a cooler in the trunk of a Prius?
Discussion in 'Gen 4 Prius Main Forum' started by priusmouse, Aug 15, 2023.
  1. priusmouse
    priusmouse Member
    253
    84
    Long Island, NY
    2023 Prius
    My current Prius is a gen 4 tho i’ll be receiving a gen 5 soon (according to my dealer anyway…lol)
    In any case, I am using one of those big rotomolded 65 liter coolers for the first time.
    It occurred to me that this will be a very heavy and hard-sided object in the trunk, near the glass of the hatch, etc.
    Is it necessary/a good idea to tie it down? Or overkill? If you think it should be tied down…is there even a way to do that in the gen 4 model? I found some hooks in mine close to the opening but im not sure theyre in the right spot to tie down my cooler (yeti tundra 65)
    49,844
    if you tie down everything you buy and bring home in the hatch, then i suppose so. might depend on how you drive as well
    BiomedO1 likes this.
  3. BiomedO1
    BiomedO1 Senior Member
    1,678
    867
    SacTown, Ca
    If you can squeeze it in with out unlatching the back seats, it should be fine. Just be careful slamming the rear hatch; you may break the glass.
    If you have to lower the back seats, I'd tie it down enough - so it doesn't become a projectile and break my back or neck in a abrupt stop or rear end collision.
    Hope this helps....
    sam spade 2 likes this.
  4. hill
    8,298
    Turns on how much of a psychotic crazed wacko Speed Demon Corner hugging driver you are. On the other end of the spectrum, I left a pair of C-clamp vise grips on the passenger Step Up sitting on the Mercedes motorhome and when we drove 100 miles down to Lake Placid Montana, lo & behold my wife opens her door and says, "you've got to be kidding". They were still sitting there. LOL
  5. sylvaing
    sylvaing Senior Member
    1,167
    490
    You're driving a gen4 Prius, are you sure you can accelerate fast enough to tumble a heavy cooler in the trunk?
  6. hill
    8,298
    Well, they CAN stop real fast.
  7. sylvaing
    1,167
    490
    Yeah, but it will get toward the back seat where the trunk lid is higher.
  8. douglasjre
    douglasjre Senior Member
    1,939
    669
    Null, NL
    Same reason spare is bolted. Missile in accident
    priusmouse and Mendel Leisk like this.
  9. Mendel Leisk
    39,016
    On the way to Costco recently:
    douglasjre likes this.
  10. hill
    8,298
    New rims?
  11. sylvaing
    1,167
    490
    What's the rope for?
  12. hill
    8,298
    Holds everything in place if you have to slam on the brakes presumably
  13. sylvaing
    1,167
    490
    That's what I thought too but the rope seems too loose.
  14. hill
    8,298
    Maybe - but it presumably beats using nothing
  15. Doug McC
    Doug McC Senior Member
    1,011
    381
    Midwest
    2022 Prius
    Let’s presume you don’t secure it as you evidently suspect you should. If anything did happen how hard are you going to kick yourself wishing you had followed your own instincts?
    priusmouse likes this.
  16. Mendel Leisk
    39,016
    Everything’s snugged down good.
    I never tie down coolers though. Maybe should, but it’d inconvenient for access, and they’re relatively light, “less” inertia in a crash.
    sylvaing and hill like this.
  17. bisco
    49,844
    even filled with beer?
