Show off your Rims
Discussion in 'Prime Accessories and Modifications' started by 5herw1N, Mar 27, 2018.
  1. 5herw1N
    5herw1N New Member
    Streamwood IL
    all Prime please show off your rims, size of it offset and so I’m rim shopping and would like to see what others have or dealt with.
    Has your mpge changed?
    Bring it!
  2. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Saved for later....
    Rob43
  3. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Stock rims, just powdered coated wet glossy black
    Montgomery, Tips, Nathanimal and 2 others like this.
  4. MSAGRO
    MSAGRO 2010 Prius Five with Advanced Technology Package
    259
    227
    Portland Oregon
    6C54CD77-8D67-4547-9703-569040619DAF.jpeg Putting these on next week...17”.
    Will post when mounted.
  5. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    #5 Rob43, Mar 29, 2018
  6. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    #6 Rob43, Mar 29, 2018
    5herw1N likes this.
  7. 5herw1N
    5herw1N New Member
    Streamwood IL
    68EB45F2-FD93-474C-A083-D77FAB2283E3.jpeg B7885F2C-FC0F-470C-8048-441298C02ADA.jpeg Decided to ask if anyone has drop a set of 17 x 8.5, 30+ offset with no intention of lowering the Prime.
    Planning on pulling the trigger to get this.
    However, really want to know who has done a large and wide rim for 2017 Prime’s?
  8. 5herw1N
    5herw1N New Member
    Streamwood IL
    What’s the purpose of this o-rings ?
  9. 5herw1N
    5herw1N New Member
    Streamwood IL
    What’s the offset?
  10. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Hubcentric rings help to ensure a perfectly centered wheel on the chassis hub, relying on just the 5x100 bolt pattern
    does not guarantee a smooth ride.
    What size tire are you planning on running ??
    Concerning your wheel choice: The wheel will stick out about ~35mm's more & the tires will stick out about ~25mm's more.
    You might want to mock something up on your current wheels/tires to make sure it works...
    Fuel economy will take a BIG hit with your proposed combo, be prepared.
    Rob43
    #10 Rob43, Mar 29, 2018
  11. Mendel Leisk
    41,928
    A little further on that: any aftermarket rim will have an oversized hub opening, basically one-size-fits-all. Toyota rims will have openings that are same size as hub (plus a slight clearance tolerance), don't need adapter rings.
    5herw1N likes this.
  12. NorTex Prime
    NorTex Prime New Member
    Lewisville Texas
    17” 86 wheels with 20mm spacers. Had to run spacers so the front wheels would not hit the brake caliper.
    GTprii likes this.
  13. 5herw1N
    5herw1N New Member
    Streamwood IL
    So by having these spacers is because the offset of the rim is not ideal spacing?
    Why can’t the rim itself just be all in one with the proper offset rather than applying a O-ring and expect the worst of it breaking apart and have an accident ‍♂️
  14. 5herw1N
    5herw1N New Member
    Streamwood IL
    Come on guys! Amazon o-rings will fail somewhat and destroying our cars LOL! NOPE!
    Do it Right, and spend the perfect rims = beautiful hybrids
  15. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    It sounds like you're confusing hubcentric rings & wheel spacers, whether you are or are not, you should spend a little time researching these things before you dive into your proposed aftermarket wheel/tire purchase.
    Rob43
  16. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Based on this statement, you really don't understand how this stuff works yet. Please do some reading....
    Rob43
    Apollo2TheMoon likes this.
  17. 5herw1N
    5herw1N New Member
    Streamwood IL
  18. 5herw1N
    5herw1N New Member
    Streamwood IL
    :p:LOL:
  19. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    LOL, please buy the wheels you want & the corresponding tires, it will be an expensive lesson for you...
    Oh, & just so we're clear, the hubcentric rings I linked are made out of metal.
    Rob43
    5herw1N likes this.
  20. Travis64
    Travis64 Member
    Ny
    More pics please ...looks good
    How much did they charge?
