showing full tank of gas, car won't start, then showing empty
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SunYellow, Jul 2, 2013.
  1. SunYellow
    SunYellow New Member
    Chicago, IL
    I picked up my new to me 2008 Touring Prius last night from the dealership (Mazda not Toyota)- happy to see the tank looked full. I started and stopped the car on two errands after picking up the car, and the gas tank still showed full.
    This morning the car would not start after the first attempt, after the second all the lights came on including the red triangle, and on the third attempt the car started but the last pip is flashing. Any ideas on what might have happened and what I should do next?
  2. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    With any electrical or other weird issues with the Prius, always suspect the 12V battery until that possibility is eliminated. Get the voltages with the method in this thread and report them back here just to eliminate this as a cause. Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    This method can also be used without turning the headlights on and off three times by using the parking lights instead.
    uart likes this.
  3. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    *Edit - SteveLee beat me to it :)
    Hi SunYellow, congrats on the new to you Prius, though sorry to hear about that issue.
    You'll find here that a lot of weird issues can be explained by a bad 12 volt battery, here are the instructions to test it yourself...Entering Maintenance Mode (aka 12V Battery Check) without Switching Headlights ON/OFF | PriusChat
    Check the voltage there, its most likely your battery is bad if they never changed it out, I also bought an '08 with a bad 12 volt battery but got it replaced by the dealer. Mazda may still cover it since you just bought it.
  4. SunYellow
    Chicago, IL
    Thanks SteveLee and Pius_Club! I will definitely be checking the 12V battery ASAP. I'll let you know how it goes.
  5. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    223
    Nature coast, Florida
    Three Touring
    If it is the 12Volt, the car probably sat for awhile without being started long enough to charge. Good luck with your new Touring Edition!
  6. SunYellow
    Chicago, IL
    Again had a hard time getting her started this evening... let alone test the battery. Performed the first battery check with switching the headlights on and off and got a 9.9 reading- yikes! Guess I'm going to buy a new battery and see if that works. Hoping that's all it is, and not a more serious electrical problem. Thanks again for all your help!
  7. SunYellow
    Chicago, IL
    And by battery, I mean a 12V of course ;)
  8. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    The Dealership should handle the Battery for you, even if purchased "as-is". That's $200-$300.
  9. SteveLee
    645
    180
    North Carolina
    I
    The dealer should replace the battery. But if he leaves you holding the bag you should do some research here on battery alternatives to the overpriced OEM. Please update us on the outcome when you can.
  10. SunYellow
    Chicago, IL
    To start, thanks once again for all your help! PriusChat is beyond awesome, and I am loving this community! In the end I decided to just buy the Optima and replace myself, with the guidance of my experienced dad and the PriusChat community. (Came to this conclusion because the battery was so dead it wouldn't take a charge, and the car would have to be towed to the burbs for the dealer to replace the battery with the same OEM, and I really wanted the Optima.) I replaced the battery today with the Optima, and it was a success! Fuel gage is showing full, and I am one happy driver.
  11. bisco
    49,443
    congrats, all the best!(y)
  12. SunYellow
    Chicago, IL
    Thanks, bisco!
  13. Patrick Wong
    18,200
    6,472
    You might take the battery receipt to the used car dealer sales manager and ask if they will write you a check.
