Shrinking gas tank???
Discussion in 'Gen 2 Prius Main Forum' started by tsunami, Oct 22, 2009.
  1. tsunami
    tsunami Junior Member
    27
    Raleigh
    This is my first fall with a Prius and I have noticed that while my MPG has remained constant, all of a sudden my first pip (really the tenth) goes away around 125 miles versus 145 for the whole summer. Is this where my bladder has experienced shrinkage;)?
    Kirk
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Yes. It happens with the Gen II Prius.
    Tom
  3. David Beale
    David Beale Senior Member
    5,963
    1,982
    Edmonton Alberta
    It's not actually shrinking. It just gets a little stiffer so doesn't get pressed into the hard tank as far from the weight of the fuel. It's a common misconception that it is -pressure- that expands it. It's actually the weight of the fuel.
    "There is no pressure, grasshopper." ;)
  4. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Incorrect on both counts (although the 2nd is a partial.) The bladder does shrink substantially as the weather becomes colder, up to about 15% depending on conditions. The manual even mentions this. Polymers have a larger coefficient of thermal expansion than metals, so it is more noticeable with this tank, and particularly in such a small tank.
    It does get stiffer as well with the cold, but that is in addition to shrinking.
    There is some vapor pressure to deal with in the tank (one of the reasons it can belch during a fill), but depending on fuel blend and ambient conditions that will differ. The system is kept at around local atmospheric pressure. However, the problem with saying there is no pressure is that the "weight of the fuel" is indeed the hydrostatic pressure of the fluid column. Pressure = F/A and P = rho * g * h. Neglecting to properly account for such pressure results in spectacular failures (see the Katrina flooding in New Orleans for an example of hydrostatic pressure undermining a poorly engineered and improperly constructed levee.)
  5. priusincc
    priusincc Member
    332
    16
    NV
    Bladder shrinkage notwithstanding, the first pip will go out at varying mileage depending on how much you fuel up and the average mpg.
    From a survey of my first 13 tanks of gas the first (or 10th) pip went out anywhere from 79 to 245 miles.
    Does the Gen III still have a bladder?
  6. brick
    brick Active Member
    1,083
    78
    Upstate NY
    No.
  7. tsunami
    27
    Raleigh
    I know that, that is a daha :rolleyes:, which is why I said mine has been 145ish all summer. So it went from 145 for ten tanks full to 125 for the last two which also coincides with our first temps in the 40's and 50's this fall.
    Kirk
