Shudder, studder, vibration issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jay7777, Feb 11, 2013.
  1. Jay7777
    Jay7777 New Member
    So I've been searching the web for the last 2 weeks to learn about my newly acquired prius to learn about what is normal and what is not as far as car reactions, noise etc. Picked up a used 10 prius iv with 31k and have put 1200 miles so far. One troubling thing I have noticed is this weird shudder/vibration that occurs between 30-40mph when the throttle is at the half way point(area between the light green and dark green bar) Vibration similar to that of driving over the rumble strip on the highway but not nearly as harsh and the noise would be similar to when you have one rear window open in the car and it creates the pulsating wind noise. It doesn't do it all the time and mashing the throttle seems to alleviate the problem. It doesn't happen so much when cruising around town but it happens every time I get near the top of the incline in our office park and the car continues to lose speed until such time as I get back on the gas but it continues to do it until I turn into the parking lot. Occasionally it does it when coasting down a hill with the throttle right near the point of crossing from light green to dark green on the screen. Anyone have any ideas? Curious if I should bring it to a dealer or make the 2 hour drive back to the one I bought it from. Bonus, my company purchased another one so next week I will have one to compare it to. Thanks in advance
  2. The Dude
    The Dude Member
    197
    32
    Phoenix
    Is the car running well other than that? If so, I wouldn't be too concerned with it. As you drive your Prius more and more, you'll learn that it is a (imho of course) great driving little car, but very cheaply constructed elsewhere other than the powertrain. I've been having similar issues on my '10 since I bought it. It happens when my "power band" is near the mid line or just above and when the car is in high gear. Irritating rattle near the passenger side. Now it rattles under the dash, near the glove, in the rear, somewhere in the driver's door...POS interior is the best I can put it. It is a little car after all...after many miles on my Prius, I've learned to turn on the radio and try my best to forget about it, especially after taking in to the dealer and having them not find anything wrong with it. Good luck with your Prius, but if I were you, I'd take it to the dealer, if still under warranty, or if it's out of warranty, maybe still take it back if you bought it at a Toyota dealer and have them look at it. Most likely they will not "find" anything wrong.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    My guess is that the ICE is firing up. Can you tell when the engine starts (while in motion)? It usually happens right at the middle of the bar graph in the HSI. The engine will also spin up around 46mph regardless of what the pedal is doing.
    For myself, the engine start up has steadily becoming more noticeable over time (41K miles now). Perhaps the plugs are getting fouled, timings issues, etc. It certainly isn't as smooth as with was when it was new.
    I have to admit though, there might be more to it than it seems. Have it checked out by the dealer.
    Welcome aboard!
  4. Jay7777
    Jay7777 New Member
    Thanks for the responses guys. Car runs great other then that one issue, amazing little car. I can't get it to duplicate anywhere except for in the office park on the hill at the presentl. At the bottom of the hill I'm doing 50 near the top before it starts to happen I'm doing about 35mph and the screen is bouncing throttle response back and forth between the light an dark green area....half way point. I've got 4k and 3 months before the 3yr/36k is up so I may bring it in if I get a chance, it's just odd b/c its particular to this one spot so far. I pick up a 2011 four for the company tom so I'll see if that one does it as well. The noise/feeling is probably more inline with the pulsating noise you get with one window down. Also, this is in eco or normal.....in power it hasn't done it yet.......once more piece to add to the mystery.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yeah, you want to get it in and at least report the issue before the warranty is up. That might help later down the line if there is a major failure to the issue.
  6. briank101
    briank101 Member
    170
    68
    Western Chicagoland
    I can recreate this engine vibration rather easily.... when driving about mid-30s to mid-40s mph up a very slight incline or accelerating slowing on the flat, and with the HSI display, adjust the throttle such that the HSI bar is right under the "O" in the ECO symbol, one should feel or maybe hear this. In my mind I think of this as an efficiency sweet spot, getting good tractive force for the fuel used, with part of it turning into stored potential energy (almost fully recoverable) when altitude is increasing, ready for the next zero fuel use downhill glide. If this vibration does indeed indicate an efficiency sweep spot, it nice to have aural feedback instead of visual feedback (HSI) for safety reasons. But other sites I've read suggest that "near lugging" is good for mpg or L/100km.
  7. Jay7777
    Jay7777 New Member
    Update.....After picking up the 2011 prius iv, it creates the same exact shudder/pulse as the 2010 under the same conditions as well as in the same spot in the office park. My conclusion, it's normal....similar to brian's response above.
  8. bisco
    52,405
    concur.
  9. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    A Scan guage helps me keep on eye on the ICE start ups when I see the RPM value go from 0 to a few hundred rpm.
    When the radio is on and the aftermarket speakers vibrating around me, I can not hear or feel when the ICE starts up. That being said I do drive with the radio off one day, every 6 to 8 weeks to hear and observe the noises and rattles that might be new to the car.
    I can say there are some systems, normal hybrid, noises before the ICE comes on that have gotten a little louder over time. Never in a bad way more like a used car kinda way.
    That strange vibration, try driving in Power mode and see if you can feel it more or less?
  10. Max butcher
    Max butcher Junior Member
    nashville, in
    I have exactly the same issue. My 2011 has 230K and this problem just started showing up. All you have to do is run about 45 mpy and ever so gradually cycle back and forth between slight accel and then slight de-accel. You can feel the vibration very easily. It didn't do this at all until now. When using the "ECO" versus "POWER" "Band Chart", its about at the 75% position on the band from left to right. Always at the 75% position. Getting worse.... Wonder how much$$ to fix it.
