Shudder when at stop
Discussion in 'Generation 1 Prius Discussion' started by Ashuri, Sep 29, 2013.
  1. Ashuri
    Ashuri Junior Member
    22
    Help
    From time to time when I come to a stop at light the car will shudder...about a minute or so....that's it no noise,etc just that
    Any ideas?
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    If it is "shuddering" at a stop for up to a minute,- my best thought is that your vehicle is still under warranty. Take it to the dealer and show them.
    You say, "From Time to Time" but hopefully you could get it to manifest at the dealership.
    51,139
    you are in the gen I forum. you might get more help in the prius v forum, assuming that is what you have, all the best!(y)
  4. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    The OP has in the past posted they bought a Prius v and also a Gen 1. So if they are talking about the v, just report the post and it can get moved. If not, it's fine where it is.
    Ashuri likes this.
  5. Ashuri
    22
    I'm asking abt my 2001 sorry no warranty on this one any ideas? Thanks
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    My thoughts are, this is normal. This is the car running the engine to get to S4.
  7. bwilson4web
    16,010
    We need a few details:
    • How often?
    • Where are you located?
    • How long have you had this car?
    • What maintenance has been done as in oil, coolant, spark plugs?
    • Are there any error codes or light on?
  8. Ashuri
    22
    Everyday at least twice a day
    Los Angeles
    2 months
    Oil,coolant,air and cabin filter change
    No
    Thanks
  9. bwilson4web
    16,010
    Ok, I'm going to offer some suggestions:
    • check for a sticky throttle - normally a problem in colder climates, nothing keeps it from accumulating and showing a problem in warm climates
    • spark plugs - they don't last forever and as they age, they become marginal (search this forum)
    • fuel injectors - they can get sticky and lead to uneven engine operation (search this forum). A bottle of injector cleaner might help.
    Now these are hypothesis. The sticky throttle is the easiest to address. Sparkplugs are more expensive but don't take much time. Fuel injectors have to be sent off for professional cleaning so the car can be down for a week and it is a little involved.
    Now the car can record codes that do not show up at an error light. In fact, the first time some codes occur, the 'check engine' light can come on but three starts later, the light is off. These recorded codes exist in the control computers. So I would suggest getting a Prius-aware, OBD scanner. Search through this forum to see what is available and we can discuss what makes sense for you.
    Do you have metric tools and an interest in doing the work yourself? If not, there may be a local, independent Prius shop that might be able to do the work for you. If you'll call these folks, they may have some recommendations: Auto Careers Development Center - Hybrid and Electric Vehicle Repair Training
    GOOD LUCK!
  10. Ashuri
    22
    Very detailed! Thank you Bob
    Will check these and report back
  11. ChapmanF
    17,326
    The stored codes will be the easiest way to check. For bad injectors (if they're all bad-ish), look for a P0171 code, or long-term fuel trim at or near 20% (the maximum adjustment the ECU can learn to make). Possibly those signs would be absent if somehow a single injector only was bad. A stethoscope on the injectors while the engine runs might help; they should make sharp ticking/ringing sounds; muffled thumps indicate cleaning needed.
    It's probably a waste of time to bother the injectors unless you first have some definite reason to suspect them.
    If you find evidence to suspect your injectors, I still have a recently professionally reconditioned set of four with test results, if it would inconvenience you to send your own in and wait for turnaround.
    -Chap
    bwilson4web likes this.
