Shuddering and vibration when starting out
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jared, May 31, 2016.
  1. Jared
    Jared Member
    209
    Long Island
    My 2010 Prius has starting to shudder and vibrate a bit on occasion when starting to accelerate as in stop and go traffic. It seems to happen mainly when the electric charge is low and the engine is on charging the battery and then I start to accelerate at the same time. It goes away once the speed in over 10mph. It happens occasionally, not every time. Never used to do this. Car has about 160k miles. Could it be a problem with the transmission device? Thanks for any input.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    your intake manifold holes are clogged and need to be cleaned
  3. JC91006
    16,673
    8,518
    Are there any dash lights on?
  4. Jared
    Jared Member
    209
    Long Island
    Thanks,
    I will check this.
  5. Jared
    Jared Member
    209
    Long Island
    No lights on.
    I did have a low oil warning some months ago because the car now burns about a quart of oil every 2000 miles. I have to top it up between oil changes.
  6. JC91006
    16,673
    8,518
    Where is this exactly?
  7. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    Hesitate to put in $.02,as others have more experience, but with that oil consumption you might just want to check for spark-plug fouling if you are already disassembling it to get to the manifold. The condition you cite seems to me to be a high-load condition and a spark plug misfire usually is more noticeable under high load.
  8. Jared
    Jared Member
    209
    Long Island
    Thanks. It could be the spark plugs. They were last changed at 100k.
  9. Former Member 68813
    3,524
    983
    US
  10. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    I'd have them check the engine mounts...maybe transmission/drive train mounts
