Shut down the car
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hong Kong Prius, Nov 6, 2016.
  1. Hong Kong Prius
    Hong Kong Prius New Member
    Hong Kong
    When I park the car, the engine is usually on because it is charing the battery (it happens to remain less electricity after a ride), can i shut down the car even when the engine is on or should i wait until the engine is off automatically until the battery is completed charging?
    Thanks.
  2. slewinson
    slewinson Junior Member
    36
    30
    Australia
    Shut it down any time. The hybrid system will manage the battery.
    Simon
    49,377
    just don't shut it down while the engine is cold.
  4. Mendel Leisk
    38,647
    Yeah, this is one caution. I'm normally very quick to shut down a car, don't like idling, wasting gas. But if you for example start the car with a cold engine (the car has sat for hours or overnight), just to move it a few feet, better parking space or whatever, then it's a good idea to let it run 'till it shuts down the engine by itself. Then shut the car off. It shouldn't take more than 3~4 minutes.
    There's a problem, at least with third gen (2010~2015): if you run the cold car for just a moment then shut down, at the next start up there can be bad shaking. Doesn't sound good, might be damaging. Toyota doesn't seem to be acting on this effectively on this, has issued some Service Bulletins, but the fixes so far don't seem to have stopped the problem.
