Shutting off. Battery charge drops suddenly.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TiffanyP, Sep 17, 2013.
  1. TiffanyP
    TiffanyP New Member
    I
    OK this is my first post and its not my car (its my father in laws). The other day his 05 prius (170k miles) shut off while he was driving. He pushed it home and I sent him a link on how to check the 12v battery. He said it showed it was low so he used his golf cart battery to go and take it for a test drive to see if that fixed the problem. In the drive way at idle his hybrid battery charge went up half way but when he went to drive it he got 1/8th of a mile down the road and it dropped to 0 then the car shut off again. He said the display says something about the battery (I havent been over to look at the car). They are sure its the hybrid battery, but if it was me I'd go to the dealer and find out for sure. My husbands aunt had her hybrid battery go out and hers did other things, like go into turtle mode and a/c blew hot. I think her inverter pump went out and she kept driving it till the battery got messed up, but anyway...What does my father in laws symptoms sound like? Is there any extra at home testing that can be done? Thanks for bearing with me, I dont know all the lingo so talk slow and use small words. :p
  2. usnavystgc
    3,159
    989
    Tucson, AZ
    1) Have the codes read at the dealer and post them here (including info codes)
    2) I don't trust the Golf cart battery. Get a new one, you need it anyway.
    3) Check for flow in the inv coolant reservoir (the car should be on and you will observe flow or turbulence in the reservoir)
    If you do step 2 b4 step 1, you will clear the codes and the dealer won't be able to read them.
    Step 3 may be done at any time.
