Side marker lights
Discussion in 'Gen 2 Prius Accessories & Modifications' started by WNY-HYBRID, Apr 20, 2014.
  1. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    I'm looking to remove the badges on my 08 prius fenders. There is a small hole under the hybrid badge, intended for non-us vehicles for a side marker light. Anyone have a source for a less expensive light? Sigma sells the JDM lenses but there 100.00
    Mike
  2. CatsAreGods
    CatsAreGods Junior Member
    46
    I'm following this thread because 10 years ago, I came close to manufacturing sequential flashing side marker lights and it's still a vague dream for some reason :)
    Nexus 4 ?
  3. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Ill buy!!!!!
  4. CatsAreGods
    46
    Well, that's one :)
    Nexus 4 ?
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    I was actually looking to do something similar, the BMW side marker lights looked to be of dimensions that would cover those two holes on the later model Gen2 Prius.
    Would just need to cut a 3rd larger hole for the side marker light but it should cover the two pin holes from the 'Hybrid' emblem. Kind of a big deal to cut into the fender...."measure twice, cut once!"
  6. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Where is this light? Hella makes a marker light too 25.00 for the set but you have to cut a oval hole. I was looking for a light that was relatively flat with3m tape on the back. and possibly running the wire through the small hole on the fender.
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    hmm.. haven't seen anything like that. All the ones i have seen require the larger hole to be cut.
