Side Mirror opening too far
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Warramoos, Oct 17, 2021.
  1. Warramoos
    Warramoos New Member
    Brisbane, Australia
    i-Tech
    Hi All,
    The right hand side door mirror of our Prius V, when you turn on the car, folds out too far and ends up point forward instead of to the side.
    See attached jpg.
    If you hold it, it just keeps trying to turn, when you let go it continues to open up all the way.
    Any ideas on how to fix this?
    Thanks in advance,
    Warramoos
  2. Air_Boss
    Air_Boss Senior Member
    4,171
    1,169
    New Yawk
    Is this car new to you, or was it recently serviced?
  3. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    Are you saying that you turn on the car, and the mirror moves on its own, as if it is driven by a motor?
    I am not aware of a Prius V package that has motors for retracting the side mirrors. An aftermarket part gone bad?
  4. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    gromittoo likes this.
  5. xliderider
    8,140
    3,274
    Honolulu, HI
    I admit that I know nothing about the internals of the folding side mirror.
    The motor most likely has a mechanism, like the one in garage door openers, that is a screw mechanism with a "flag", usually a small tab of plastic that interrupts a sensor to tell the motor to stop. Perhaps the sensor or flag has somehow become non-functional causing the overtravel seen.
    Air_Boss and Warramoos like this.
  6. Warramoos
    Brisbane, Australia
    i-Tech
    We purchased the car 2nd hand about a year ago. Its only started doing this.
    Air_Boss likes this.
  7. Warramoos
    Brisbane, Australia
    i-Tech
    The Mirror has a motor in it - I pulled it apart the other day, hoping to find, as you mentioned - some type of predefined stops, or a "flag" or "tab", but can't seem to find anything external on the motor housing. It maybe a mechanism internal of the motor, but didn't get too far into pulling that apart.
    I agree - there must be some sensor maybe within the motor that has "moved" as it stops - just not in the correct location.
    Thanks, I'll keep playing. In the meantime - I think I'll just disconnect the "motor" and leave it as a static mirror.
    xliderider and Air_Boss like this.
  8. Air_Boss
    4,171
    1,169
    New Yawk
    Or the mirror rotation indexing system needs to be re-clocked or re-calibrated. Is there not a detent at the previous normal rotation/extension position?
  9. gromittoo
    719
    288
    philadelphia
    2013 Prius v wagon
    So that explains why the OP said right side mirror, rather than passenger side Mirror... since Australia is Right Hand Drive.
  10. xliderider
    8,140
    3,274
    Honolulu, HI
    If the motor is a stepper motor that counts "steps" to get to specific locations, or indexes, it could have lost calibration somehow.
    I assume the OP had to disconnect power to the assembly to remove it, but did the OP simply try a reboot (power off/on), maybe as simple as unplugging reconnecting the harness to see if it would reset?
  11. Warramoos
    Brisbane, Australia
    i-Tech
    Thanks for your comments. Yeah we tried just turning the car on and off and that didn't fix things. We disconnected the harness when we pulled it apart, but it acted the same when we reassembled it. Its definitely a "stepper" motor of sorts. you can manually turn the mechanism and it clunks into predefined steps - but it doesn't align any more. I'll look into seeing how to recalibrate the stepper motor. Will have a play over the weekend. Thanks everyone for your thoughts.
