Sidewall lip on 215/45-17 Bridgestone Turanza EL400-02 (Prius V)
Discussion in 'Gen 3 Prius Main Forum' started by 32kcolors, Jul 20, 2009.
  1. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    On the 215/45-17 Bridgestone Turanza EL400-02 found on some Prius package Vs, there's a lip surrounding the innermost edge of the sidewall and it protrudes out in front of the 17" rims. It was the first thing I noticed when I got the car and thought it was pretty cool looking, but didn't know what, if any, purpose it serves. I looked at the high resolution picture of a Bridgestone Turanza EL400-02 and cannot find this "lip." Do owners of the Vs with Michelin Pilot HX MXM4 or Toyo Proxes A20 have this feature on their tires?
  2. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Yep - I have the 17" Toyos. Was pleasantly surprised to see the convex ridge all the way around. Must be a bit of defense for alloy wheel scrub on curbs... Nice design.
  3. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    That's what I suspect, but is that all it does? It must also be tire size dependent because the hi-res photo on Tirerack doesn't have it.
  4. Tideland Prius
    16,559
    It's a rim protector against curb damage. It's usually only on lower profile tyres (such as those on the "V". 215/45R17 are pretty sporty. They're found on sporty cars like the Lexus IS). You won't see them on smaller tyres.
  5. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Tideland,
    Your answer would be my first guess too.
    That said, I wonder if the ridge might also have an aerodynamic purpose
    as well, that being to direct the air passing over the rim/tires outward
    just a smidge and perhaps even bridge over the gap between the rear of
    the tire and the bodywork.
    Maybe a lucky Gen III owner could do some tuft testing and take pictures
    to see what the OEM airflow down there looks like.
  6. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    It has nothing to do with aerodynamics--it's to protect the wheels on low profile tires. I've had it on all my cars for the last 10+ years.
  7. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    The Scion wheels I just bought with those tires have them "lip" it is to rotect the rims from curb damage. I know for sure the Goodyear Eagle GT also has them in that size as well.
  8. Tideland Prius
    16,559
    What stream said. It's not specific to the Prius. Most newer tyres of these dimensions will have a rim protector built in. They're not present on the same tyre model but of higher sidewall height and/or smaller tyre size.
  9. jim256
    jim256 Member
    317
    69
    Eastern NC
    Correct, and FYI my Lexus IS 350 (factory Bridgestone Turanza ER33) has it on the front 225/40 R18 but not on the rear 255/40 R18. It all depends on the tire and size, I guess.
  10. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Do all tires in a specific size (e.g. 215/45-17 on Prius V or 225/40-18 on IS 350) have the sidewall lip/convex ridge? Or does it depend on the tire brand? Better yet, how do I find out whether or not a particular brand/size has it? I spotted a new Mazda 3 with 205/50-17 Goodyear Eagle RS A and the tires lack the rim protector.
  11. sdtundra
    1,314
    193
    Sacramento, CA
    Put 2 new Cooper CS4's on the Camry and Express had a set of 4 Toyo Proxes 245/45ZR17 with the rim protector in the showroom, but the 235 width didn't. My mom's Infiniti G35 Coupe has Falken Ziez 512. Front 225/40/17 with rim protector and 245/45/17 rear also with protector. It seems the higher performance tires have them.
  12. jim256
    jim256 Member
    317
    69
    Eastern NC
    My guess, based on the on the front versus rear disparity on mine and the visual appearance (225 front 255 rear, all else the same), is that it depends on the vertical distance to the base of the wheel. Whether that's unique by tire manufacturer, or a common standard, I have no idea. Start with picture comparisons at a place like Tire Rack, if the picture is clear, or call them. They usually have a good handle on their products.
