Sight lines for the shorties (like me)
Discussion in 'Gen 3 Prius Main Forum' started by Fantine, Jun 13, 2010.
  1. Fantine
    Fantine New Member
    Washington, DC
    I'd like to get some opinions from my fellow shorties (I'm a five foot woman) as to how good the slight lines are in the new Prius. I currently drive a 2007 Hyundai Elantra, which is a good car for shorties because the driver's seat sits very high for a compact and the rear seat head rests are very low.
    Thanks in advance.
  2. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    The driver's seat does jack up a bit. However, line-of-sight in the Gen III is limited. I strongly advise a test drive to see for yourself. Moreover, blind spot familiarity and visualization of the 4 corners do come more apparent the more you drive. I guess I'm saying--It takes practice no matter how tall you are to become accustom to your placing between the white lines.
  3. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    It does jack up quite a bit, though. "Jack" is the operative word. To raise the seat, you repeatedly pull UP on the handle. Each pull gains you a skosh. To lower it, push DOWN on the handle. Each push yields a small descent.
  4. Tideland Prius
    16,147
    The rear spoiler might be an issue for shorter folks in terms of rear view visibility. I'm tall so the spoiler doesn't bother me. If it does bother you, then perhaps consider a backup camera. (unfortunately it is bundled with the nav in the US)
  5. andino
    andino Senior Member
    746
    550
    San Jose, CA
    I'm not too short (5'10") but i'm currently driving an s60 volvo, the GenIII has a great field of visibility everywhere except I wasn't quite used to how long the front end felt.
  6. homersparkey
    homersparkey Older but not Senior Member
    Raleigh, NC
    I'm only 5'2" and I did have trouble seeing all around for a while - until I put a chair cushion on the seat. (I had already raised the seat but it still wasn't high enough.)
    Didn't have this problem in my 2004 Prius.
