Significant reduction in MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by Nickp001, May 31, 2006.
  1. Nickp001
    Nickp001 New Member
    I recently had new tires put on my car (Goodyear ComfortTread's) and had an oil change. At the tire place I asked them to put 42psi in the front and 40 in the rear. This is when I really began noticing a significant drop in MPG, about 3-5 MPG to be exact. I was averaging between 44 and 45 before the new tires and now I was not even hitting 40.
    Then I went to Jiffy Lube for a MobileOne oil change. I asked them to make sure the oil level was at the line and not a hair over. I also asked them to check the tire pressure, again 42 in the front and 40 in the rear. They said the tire pressure was off, and they said they made the necessary adjustments.
    I was still getting poor mileage, so I decided to check the tire pressure and oil level myself. Tire pressure was set at 35 all the way around, so I adjusted it to 42/40. Oil level appeared to be ok, but it was really hard to read. I'd get different results every time I pulled the dip stick out.
    After adjusting the tire pressure, I was still getting poor mileage, so I tried 44/42. No Change. Went to 40/38 and noticed a slight improvement, but sill only averaging about 40 mpg. Is it possible that this decrease in mileage is due to the new tires?
    Should I expect the manufacturer installed tires to outperform the ComfortTreads in mileage? Very disappointing if that's the case. :(
  2. ncc1701mda
    ncc1701mda Junior Member
    22
    I wonder if the tire diameter is different than the original tires? That could affect what the system thinks it is getting for mpg.
  3. Nickp001
    Nickp001 New Member
    <div class='quotetop'>QUOTE(ncc1701mda @ May 31 2006, 07:49 AM) [snapback]263373[/snapback]</div>
    When I ordered the tires I ordered P185/65R15's, but I should probably check and make sure they installed what I asked for. Another thing I should do is calculate actual mileage and not just rely on the cars calculations.
  4. marcdare
    marcdare New Member
    51
    Los Angeles
    <div class='quotetop'>QUOTE(Nickp001 @ May 31 2006, 09:14 AM) [snapback]263356[/snapback]</div>
    There is a whole thing in the manual about changing tires. Anything besides the manufactuerd tires for the car need to be entered into the system. I'm pretty sure you have to account for the dimensions of the tire, because even tiny insignificant changes over hundreds of miles greatly affects the output on the screen. I wish I could be less vague, but look in your manual and you will find it.
  5. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    new tire breakin is a big MPG killer. i wonder if they're also not LRR (low rolling resistance) tires- that would have an effect too. there are plenty of others here who have changed to the comfortreads- if you do a quick search i'm sure you'll find plenty of opinions.
  6. Nickp001
    Nickp001 New Member
    <div class='quotetop'>QUOTE(galaxee @ May 31 2006, 08:07 AM) [snapback]263381[/snapback]</div>
    Yeah, I wonder if that has something to do with it. Incidentally, over the past couple of weeks I had done several searches here hoping to find something. I did find a brief mention of a similar problem with the ComfortTreads, but not much else. Thanks!
    <div class='quotetop'>QUOTE(Greenfoot @ May 31 2006, 08:05 AM) [snapback]263380[/snapback]</div>
    I'll have a look and see what I can find. Thanks for the suggestion.
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    There have been a number of posts on the subject of tire break in. I think you need to be prepared to take a hit. We all feel for you. We will each have a turn at this and it will be difficult. I am going to do mine in winter if possible so I can blame the weather. The spring is a bad time, I look forward to the rising MPG and get depressed every time the weather takes a turn for the worse.
  8. Nickp001
    Nickp001 New Member
    <div class='quotetop'>QUOTE(hdrygas @ May 31 2006, 07:45 PM) [snapback]263798[/snapback]</div>
    Thanks for your input. I took your advice and read several posts regarding the tire break in period and that could very well be where I'm at right now. I'll keep my eye on it and see if it improves over time.
  9. MikeV
    MikeV Junior Member
    95
    philadelphia
    Did you solve this
  10. james nancy
    james nancy Member
    110
    24
    suva,fiji
    New tires will lower the mpg, which is in line with my previous experience. The mpg of bare tires is the best. Of course, it will affect the braking distance and even the safety performance. You can try to adjust the toe of the front wheel. If the 0 toe feels stable while driving, keep it. This is the best fuel economy performance. The toe of the rear wheel is tested. It will have an impact on the driving resistance. You can use a tape measure to measure the front and rear track of the tire. The track difference is the toe, preferably 0 or slightly negative, because the rear wheel inclination is generally a small negative value, and the toe adjustment of the rear wheel can be used The method of adding spacers is realized.
  11. dolj
    dolj Senior Member
    7,475
    3,760
    Wellington, New Zealand
    That may be your experience, but it does not follow that all new tires will reduce MPG. There are many factors to do with the rolling resistance that comes into play.
    My experience is when mounting the same make and model of tire, fuel economy is unchanged.
    If you go from one make and model to another, all bets are off.
  12. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    This thread was 15 years old. Chances are that you won't get a response from the OP.
    Goodyear ComforTred tires are not a low rolling resistance tire. Goodyear's LRR tires are Assurance FuelMax.
    We have been averaging 52.X mpg on the previous set of 15 inch FuelMax tires. We just put on a new to us set of 16 inch wheels with 16 inch versions of the Assurance FuelMax tires. The rims are one pound heavier than the stock alloys. Still early to tell what mpg will be like on this set of tires.
  13. james nancy
    james nancy Member
    110
    24
    suva,fiji
    I want to explain my point of view. The new tires of the same model are different from the old ones, and the resistance of the new tires will increase a little bit. As the mileage increases, they will get better after running-in. This is my point of view.
    when the vehicle is running, even if it is driving in a straight line, the friction between the tires and the ground is not completely rolling. Due to the existence of the inclination angle and the toe (other angles are not considered when driving in a straight line), the friction will have a tendency to push, this tendency Sometimes it is to make up for the gap of the suspension system. The gap cannot be completely eliminated (in any case, the cost and driving feel of the vehicle are all compromised and compromised in the design of the vehicle). This gap will cause unstable driving conditions. Generally, driving vehicles are designed with front wheels toe in, and the rear wheels are slightly negative inclination to increase cornering grip. The existence of these angles causes the wheels to have a little sliding friction with the road surface when driving, causing the tires to hang inward or Outward or rotating force to reduce unstable factors. The existence of these angles will cause some sliding friction on the tires. Therefore, when the gap between the suspension rubber sleeves, ball joints and other movable components is small, it is recommended to adjust the toe and camber angle to 0 to reduce slippage. The generation of resistance (provided that it does not affect stability). The surface of the new tire pattern is relatively rough and deep, but also relatively soft. The same tire pressure deformation will be larger. The contraction and recovery will continue to require energy. The roughness will cause the sliding friction resistance to be greater. After a certain period of running-in, the resistance will decrease. No vehicle can completely avoid sliding friction. All you have to do is to minimize it and maintain stability as a compromise.
    What I want to say is that sometimes the toe, inclination angle and tire pressure will have a greater impact than the type of tire. If all is good, changing to a low-resistance tire will have an effect.
    #13 james nancy, Sep 1, 2021
  14. james nancy
    james nancy Member
    110
    24
    suva,fiji
    I’m sorry I just noticed that this is a post 15 years ago, I think it may have some effect on others, and the problem remains the same.
  15. Another
    Another Senior Member
    1,802
    508
    Naples, Florida
    LOL
    New Member, Nickp001 was last seen: May 17, 2009
