Signs/Symptons of Fuel Bladder failure/rupture
Discussion in 'Gen 2 Prius Technical Discussion' started by MikeyC, Feb 17, 2011.
  1. MikeyC
    MikeyC Junior Member
    West of F'Burg VA
    Gents,
    This may have been answered before but i cant find it.
    What are the Signs and Symptoms of Fuel Bladder Failure/Rupture?
    07 Prius with 63000 miles.
    My last fill up I was at two Pips and it took 8.4 gallons to fill. Outside temp was around 38. And I average arond 44MPG. (New Prius Driver)
    Also what is the Estimated/Ballpark Mileage per PIP?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Error lights. If you don't have an error code your car's bladder is fine.
    Tom
  3. Patrick Wong
    18,200
    6,472
    To be specific, the engine ECU will log a DTC if there is a problem with the fuel tank. A sensor monitors the air quality between the bladder and the fuel tank wall, and if fuel vapor is present the sensor will detect that.
    When the engine ECU logs a DTC, the check engine light will appear.
    2 people like this.
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    As above, fuel volume changes are not an indication of a failure in the fuel bladder system. They are an indication that either it's cold or the fuel pump nossle was not set correctly or your method of filling is not optimal.
  5. bisco
    49,380
    what is your issue? 8.4 gal. at 2 pips sounds about right, 44 mpg sounds about right and ball bark mileage per pip would be 50mpg (but i got that out of right field)
  6. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    There is no ballpark miles per pip. The outside temperature has a lot to do with how many miles you get per pip and it is not linear. The "guess" gauge is just an indicator. I suggest you fill up at 2 pips and you will have no problems.
  7. jrb451
    jrb451 Junior Member
    59
    Conway, AR
    Seems like you would detect an odor of gasoline if there wa a leak. I'm just saying.......
  8. bisco
    49,380
    i generally go with pips per mile.
  9. davidj08
    davidj08 Junior Member
    79
    northern CA
    Firepa is correct. I've gotten as much as 115 mi on a single pip and as little as 25. He is also correct about when to refuel. Dropping to one pip or waiting for the audio low fuel warning may be cutting it too close. David
