Silly Question, I hope.
Discussion in 'Newbie Forum' started by Wonder Bread, Sep 17, 2009.
  1. Wonder Bread
    Wonder Bread New Member
    Why is there no Heat option in my Prius? :eek: Am I supposed to
    freeze all winter? :eek: Please, Please, tell me how do I get heat? :eek:
    There's nothing about it in the Manual, either!!????
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    You are over thinking this. Temperature up gives you heat. Temperature down cools. It couldn't be simpler.
    Tom
  3. Wonder Bread
    Oh, I tried that 'til it said I couldn't go any higher- but, it was only at 80º. 80 is certainly alright, but I was wondering where will I get that blast of heat in winter from? I'm in Texas and we freeze down here when it gets to 40. I'll look at it again and see what happens! Thanks!! I thought that would be the answer!!
  4. Wonder Bread
    PS- really, we freeze at 50º here.
  5. richard schumacher
    7,663
    1,038
    United States
    80'F is the set point for the air returning to the A/C. The air blasting out of the vents will be much hotter.
  6. qbee42
    18,058
    3,073
    Northern Michigan
    It was 49° here this morning. It has to get a lot colder before we even consider heat. I was swimming four days ago.
    Tom
  7. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    If I recall correctly it goes to 85 Degrees and then says HI in the display. You will find you will be quite toasty from the heating system I assure you of that.....
    I tried mine this evening and it was quite Toasty....had to turn it off...in fact...
  8. Wonder Bread
    I swam in Wonderful Lake Michigan this summer!
    I think Bobsprius probably hit the nail on the head- I bet I had the a/c when i couldn't lift the temp above 80º
    Thanks for all the great feedback! My sales agent told me about his site. It's a great resource! :cheer2:
  9. richard schumacher
    7,663
    1,038
    United States
    Remember that "A/C" = "air conditioning", not "air cooling". A/C includes heating and dehumidifying.
  10. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Totally noob question, but is the heating system similar to conventional cars or is there type of electric heating element?
  11. qbee42
    18,058
    3,073
    Northern Michigan
    The Prius A/C system has some special features:
    1) Electrically driven direct drive variable speed sealed A/C compressor (no belts or seals, and runs only at the required speed).
    2) Fully automatic operation, including solar and humidity sensors.
    3) Electrical heater elements for fast warm up on very cold days.
    The electrical elements only come into play if you crank up the heat on a cold day. They aren't big, but they do help provide heat quickly.
    Tom
  12. richard schumacher
    7,663
    1,038
    United States
    And yes, if you call for much heat on a cold day the engine will run more often.
