Simple braking questions
Discussion in 'Newbie Forum' started by SpeedDemon, Aug 25, 2016.
  1. SpeedDemon
    SpeedDemon Junior Member
    26
    Los Angeles
    Hello Prius Nation,
    First of all, I am glad I found PC. I've posted a few times on the Gen 3 forums and I can say that out of all the different kind of forums I've been on (Audi, gaming, social, DJing, lifestyle, etc) PC is by far the most welcoming and friendly and knowledgable forumers.
    Newbie question: My understanding is when I'm braking lightly, the brakepads are not engaged and the car is slowed by a device/component turning backwards and at the same time generating energy for the battery. For example, in HSI view, the brakepads are not engaged unless CHG is fully light up, correct?
    What is the device/component called that assists with braking? Does this part wear out or need to be maintained? I can imagine it takes a lot of stress and
  2. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    Below about 7 MPH, Motor/Generator2 is not turning fast enough to slow the car, so at the end it is always friction brakes.
    Motor/Generator2 (who's speed is always proportional to the wheel speed) is used as a generator while braking. There is a fairly low limit to how much electrical energy the regenerative process can convert to battery charge, the rest will be friction brakes. (or on long downhills, engine Braking. You can aid braking on long downhills with B)
  3. SpeedDemon
    26
    Los Angeles
    Thanks for the reply. Does the Generator2 require maintenance/repairs?
  4. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    There is a radiator for the inverter and transaxle that needs new coolant, same as the.engine. There is also.ATF WS lubricating and cooling the transaxle. Routine drain and fill with new ATF seems wise. 30,000, 90,000 and then every 90,000 miles
    #4 JimboPalmer, Aug 25, 2016
    alanclarkeau likes this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    It isn't like the brakes which wear out from use, but is essentially a large alternator (also used as an electric motor) which is generating power as it takes kinetic energy from the movement of the car, slowing it down. It has proven extremely reliable, needing only routine maintenance of lubricant.
  6. Mendel Leisk
    38,751
    In a nutshell: the car has an electric motor, that can act as a motor, or, during braking, act as a generator.
    #6 Mendel Leisk, Aug 25, 2016
    CR94 and Tideland Prius like this.
  7. Tideland Prius
    16,159
    Yup they've all pretty much nailed it. During braking, it's the same motor (MG2) that drives the car forward that is going backwards and recharging the battery. Neither MG1 or MG2 requires maintenance or repair. (At least I haven't heard of anyone replacing the motors on any Toyota hybrid)
    Recall physics class (if you took physics) that an electric motor and also work as a generator. When you apply electricity, it becomes a motor generating mechanical energy (in this case, it's the axle and ultimately the wheels). When you apply mechanical force (in this case, it's the wheels rotating), then the motor generates electricity and that gets fed back to the battery.
    Mendel Leisk and alanclarkeau like this.
  8. ChapmanF
    15,701
    Re: "going backwards" MG2 is connected by fixed gearing (and a chain, in some generations) to the differential and wheels, so it's always turning the same direction any time the car is going forward, the other direction when the car moves in reverse.
    The only thing switching direction and "going backwards" when you brake is the electric current to/from the motor.
    Even that isn't anything as simple to see as switching the + and - on DC connections, because the Prius MGs are AC motors. The difference between electrically 'forwards' and 'backwards' is just something you'd be able to see on a multichannel oscilloscope where you could watch the voltage and current waveforms together. (Or just using the Torque app or a ScanGauge, etc., which just asks the car's computer, which does the math for you.)
    -Chap
    CR94 and alanclarkeau like this.
  9. jdenenberg
    jdenenberg EE Professor
    3,852
    1,854
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Actually there have been MG coil failures on a small number of Prii requiring replacement of the HSD (both MGs are part of the HSD). That is why Jimbo repeats the oft stated suggestion to do regular ATF refreshes at 30k miles and every 60k miles thereafter. A good discussion of these failures in early Prii can be found at: VIDEO - Prius P3125, P3009, P3120 - MG2 repair - Luscious Garage | Hybrid Specialists
    and at: Gen 2 Prius (2004-2009) Transmission Failure, P0AA6, P0A92, P0A7A - Luscious Garage | Hybrid Specialists in the Gen2 Prii.
    JeffD
    Tideland Prius likes this.
  10. Mendel Leisk
    38,751
    Most service intervals are miles OR months. I may just do another transaxle fluid change this fall. It's been three years since I last did one; it's been nowhere near 60,000 miles, or even 60,000 kms lol.
    It's just: tri-yearly seems a good number, not onerous. And, time MAY be a factor, ie: a low mileage short trip vehicle may deteriorate the fluid faster. Who knows, it's a cheap and easy service.
  11. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    I forget about time, as I do 30,000 miles a year so for me it is always miles. (now that I am retired, I may have to pay attention to time)
    Tideland Prius and Mendel Leisk like this.
  12. Tideland Prius
    16,159
    Thanks for the information, Jeff!
