Simple charging math
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by elmofongo, Mar 22, 2012.
  1. elmofongo
    elmofongo Member
    256
    SF, CA
    I'm trying to understand the the math behind the battery charge.
    The battery indicator has 8 bars when fully charged:
    and when the EV range is fully depleted (0 EV miles left) it shows 6 bars:
    So does that mean that the EV charge (13.3 miles) is 1/4 of the battery's capacity (1/4 x 4.4kWh)?
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    When EV runs out and the ICE starts up, the battery's state of charge is at about 23%. When it's full, it's at about 85.1%.
  3. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    So, when you run out of EV charge and you're switched to HV mode with HV display, is HV battery shown as full?
    If yes, when you deplete EV part of the battery and you, at that time, coast at 30 mph, is ICE off and you're emptying the HV part of the battery as in the regular Prius?
  4. elmofongo
    elmofongo Member
    256
    SF, CA
    But that doesn't jive with the 8-bar (EV full) versus 6-bar (EV empty) indicator symbol unless it's not a linear gauge (or I'm missing something)...
  5. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    What you are missing is that the icon for the battery gauge changes depending upon whether there is any EV range left. When there is no EV range left, the battery gauge has an 8 segment display as you've already mentioned. But when you have EV range available, it changes to a solid battery and the level of it goes up and down depending the estimated range. When you get down to about 0.6 or 0.7 miles, it changes back to the 8-segment battery display and the EV range counts down to nothing, and then it's just in regular HV mode, but with an apparently full battery for HV mode. With this bigger battery, I've only seen the top two segments disappear when in HV mode. With my 2005, I'd regularly get down to 2 or 3 battery bars.
    In the regular Prius, the battery gauge has never been linear. Each segment is not a fixed percentage of SOC available. There's overlap between the segments depending upon whether you are discharging or charging. Somebody on here had a chart showing the SOC to batery bar comparison and how it overlapped.
  6. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
    I saw 18.4% SOC when the ICE kicked in for forced charging by ScanGauge.
    Ken@Japan
    2 people like this.
