Simple Question: Oil Changes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iammegiam, Dec 18, 2015.
  1. iammegiam
    iammegiam Member
    34
    33
    Chicago, IL
    So I have a fairly simple after hearing conflicting comments:
    -- Oil changes need to be done every 10k miles with full synthetic oil (per owners manual)
    -- Oil changes need to be done every 3-5k miles with conventional oil (per Panama City Toyota dealership when taken in when the "maintenance required" light was on while on vacation from Chicago)
    -- Oil changes need to be done every 5k miles with full synthetic oil (per my regular local mechanic who argues it's because that's when the light comes on and 10k is stated in the manual so the engine goes bad quicker)
    Please clarify.
  2. JC91006
    16,827
    8,600
    Follow your owners manual, 10k mile changes with synthetic motor oil. The light comes on at 5k for tire rotations and for you to check all your fluid levels.
  3. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Compromise - Full synthetic @ 7500 miles...
    52,361
    owners manual. only conflict is people who have a vested in your wallet.:cool:
  5. Mendel Leisk
    41,873
    I like the last option, it's the Toyota spec. in Canada. It's really up to you, your comfort level. The US interval likely IS ok, but more frequent doesn't hurt.
    Personally, DIY'ing my oil changes, it's a trivial chore (and cost) every 6 months, just over $30 for supplies.
  6. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    - The first bullet is correct. Of course, you are free to change it more frequently if you like. Some use supposedly better synthetic oil and extend the interval to 15,000 miles.
    - The second bullet is also correct IF you use conventional oil and not synthetic. However, I believe the manual says something to the effect that you can use conventional oil, but you should switch back to synthetic after 5,000 miles.
    - The third bullet suggests you look for a new local mechanic or educate him on the Prius. All it should take is reviewing the maintenance schedule with him. He's probably used to cars where the light coming on DOES mean the oil needs to be changed and doesn't realize that's not the case with the Prius.
    Oh, and the 10,000 mile interval is only for the general operating conditions mentioned. There are two intervals in the manual depending on conditions.
  7. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Toyota has never changed the maintenance interval light .. it's a bit annoying. It's only a counter and I think they just never bothered to change it -- hay ......people think it equates to something ...maybe the dealers get more service out of it.
    We are at 4 years and 130k -- the car uses maybe 1/2 quart of oil in 10k miles. I buy the 5 quart 0W-20 in the big jug when it's on sale -- so I have the little extra I need.
    The oil is so clean at 7500 -- I would never change it. Frankly -- is really clean at 10k ... I don't think it really needs changing.
    Pijoto and bisco like this.
  8. bisco
    52,361
    there are two schools of thought, neither proven.
    1) the engine doesn't run the whole time, thus, less wear than a gasser.
    2) the engine starts and stops a lot, thus, more wear than a gasser.
  9. Former Member 68813
    3,524
    983
    US
  10. bisco
    52,361
    help me out, which school of thought did they prove?
  11. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    If you read Toyota's service schedule, you'll see they recommend tire rotations and other inspections at 5K mile intervals. That's the reason the 5K mile maintenance reminder pops up.
  12. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Read the manual, quite a few will be making short trips. Those who do should do 5K OCI.
    Old school refers to that type of driving as "severe service".
  13. Former Member 68813
    3,524
    983
    US
    i'm sure you're above spoon feeding.
  14. bisco
    52,361
    i wonder what the o/p thinks of all this.
