Single tire replacement?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Elt31987, Jul 11, 2019.
  1. Elt31987
    Elt31987 Active Member
    205
    149
    Derry, NH
    Need to replace a single Ecopia because the sidewall got a nail. My question is......... If all 4 tires currently have 6/32" remaining and a new tire has 10/32" can i get a single tire to put on the back so its not part of the drive-train? Id really hate to have to get all 4 when the others have more life in them, especially when i use Winter tires in the winter.
    https://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Ecopia+EP422+Plus+%28S-+or+T-Speed+Rated%29&partnum=965SR5EP422PL&vehicleSearch=true&fromCompare1=yes&autoMake=Toyota&autoYear=2016&autoModel=Prius&autoModClar=Two
    49,500
    i think it will be fine. how many miles on them?
  3. Elt31987
    205
    149
    Derry, NH
    I use snow tires from around November to March so with 75K after 3 years id say they have around 44K with 6/32" left
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Go for it - shouldn't be a problem. The Owner's Manual doesn't recommend not to. Some service centres might try to convince you to buy them in pairs though. I've done it in the past - see lots of cars like that.
    Rmay635703 and Elt31987 like this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    It should be ok on the rear. I had a new tyre on the rear of my old Prius+ that was fine, but when I decided to rotate the tyres, or more specifically, swap backs over with fronts, it threw the steering slightly off centre and made it pull to one side slightly. I swapped them back just to make sure I hadn't done something to cause this during the process and all was fine again. The steering must be very sensitive on the Prius+.
    Elt31987 likes this.
  6. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    Putting a new tire on the rear is a good idea--always put your best tires on the rear, even on FWD cars
    alanclarkeau and Elt31987 like this.
  7. Elt31987
    205
    149
    Derry, NH
    Tired arrived today and had it swapped out. Thanks for the advice
