SIRIUS RADIO
Discussion in 'Gen 3 Prius Audio and Electronics' started by Jeremy Henry, Dec 15, 2014.
  1. Jeremy Henry
    Jeremy Henry Junior Member
    MOSES LAKE
    I have a question for someone, does any one else have problems with their Sirius reception around "stuff". Mine will cut out around trees, stop signs tall people. Is there a updated antenna? Reprogram?
  2. kc410
    kc410 Active Member
    262
    251
    2010 Prius IV
    This is a _very_ common problem - seems the sat antenna is just not up to the task. Perhaps when new it worked better?
    The easiest/best "fix" appears to be splicing in a replacement generic antenna - see this thread:
    Improving XM Satellite Radio Reception | PriusChat
    I haven't done this mod - yet - because in the open I have no problems & I do not like having a mag-mount on the vehicle.
    I don't remember if anyone found an adapter for the replacement antenna connector, which left splicing the very small coax as the only option.
