sirius scc1 & toy sc1 mounting places
Discussion in 'Gen 2 Prius Audio and Electronics' started by zeroeffect4, Aug 29, 2008.
  1. zeroeffect4
    zeroeffect4 New Member
    hey fellas searched around and found the install pdf. although on the pdf there is only one sirius box, i have the scc1 and the sc1. so the cables are not long enough to mount under the rear seat. so where did you guys mount these boxes at? And were you guys able to slip the antenna wire between the hatch and the car it looks like a tight fit. thanks alot guys first time install!!
  2. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    I hope you didn't take your whole dash apart.
    Your best bet is to stack the two units together, put a rubber band around them, and stash them behind/below the far right vent, to the right of the lower glove box, and accessed by removing the lower glove box. Perfect place.
    I had placed them above the lower glove box, but they tended to overheat. See link
    http://priuschat.com/forums/audio-e...rus-satellite-radio-options-9.html#post585196
    The antenna wire can be routed through the hatch boots, as seen here
    Look at these links from the past
    http://priuschat.com/forums/prius-m...side-spoiler.html?highlight=satellite+antenna
  3. zeroeffect4
    thanks so much for the help, those pics are a lifesaver!
