For Sale Six B680AC Prius Battery Balancer Hobby Charger With Leads Kit
Discussion in 'Private Sales' started by Mavi, Oct 8, 2018.
  1. Mavi
    Mavi Active Member
    484
    283
    San Diego,ca
    2020 Prius Prime
    Hi so I'm selling my Prius charging set for balancing your prius modules.
    I have six of the B680AC 80 watt units which allow for a much faster discharge than the normal b6max's out there. They plug into the wall, not into a 12v battery for ease. They allow for 2amp discharge, 6 amp charge. With that said I only use 2a discharge and 2a charge while charging to keep the module temps low. You can also see the discharged modules mAh if you so wish to after your cycles. They all come with the hobby charger stuff which I didn't use as well: Charging Cable: TRAXXAS (TRX) Balance Cable: JST-HX (2S-6S Batteries)
    Anyways I'm selling sex of the B680AC's completed with 6 sets of harnesses (6 for positive, 6 for negative) which connect to the modules and allow for the nut to go over so that the leads never disconnect while balancing the modules.
    I invested a lot of time and money into this set, but i'll sell it for my cost. $300 plus $30 for shipping.
    Pics coming soon. Thanks
  2. Mavi
    Mavi Active Member
    484
    283
    San Diego,ca
    2020 Prius Prime
    Finally had a change to take pictures of the setup. Can also sell just 5 chargers with respective cables for $260 plus $20 shipping if you don't need all 6.
    https://imgur.com/a/jez4t7u
  3. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    Really?! :eek::po_O:ROFLMAO:
    sorrywereclosed and padroo like this.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    Why are these called B680AC on the internet, when the model number on the face of the unit says pd04000?
    They listed the same way on ebay, too. Is one just a knockoff of the other?
  5. Mavi
    Mavi Active Member
    484
    283
    San Diego,ca
    2020 Prius Prime
    Autocorrect knows humanities true desires.
    As for why, I think it's because they are rebadged B680AC's. The hobby charger market is chock full of them. They look exactly the same as far as I can tell, specs are the same, etc. These are imo much better than the clones they sell from China, better quality fan, overall operation felt better. Had a few chinese close B6's before these which i sold off as they weren't cutting it.
    SFO likes this.
  6. Mavi
    Mavi Active Member
    484
    283
    San Diego,ca
    2020 Prius Prime
    Just bumping this:
    Link to pictures.. Note now it's $200 shipped for the set, comes with 5 not 6 chargers though as of now.
    SFO likes this.
  7. irishluder
    irishluder Junior Member
    SF BayArea
    Hi Mavi... I'm interested in this setup. Still new to all this so just want to make sure this will work to load test and charge and cycle my 2ng gen battery so I can figure out which cells are bad, replace, and then use this again to charge all modules to a similar level?
    Im in NorCal so shipping should be reasonable.
    edit: was able to copy the link and it worked
  8. oklaprius
    oklaprius Junior Member
    Oklahoma
    Sent you a PM.
  9. Mavi
    Mavi Active Member
    484
    283
    San Diego,ca
    2020 Prius Prime
    Replied to pm's sent.
    Raytheeagle likes this.
  10. Mavi
    Mavi Active Member
    484
    283
    San Diego,ca
    2020 Prius Prime
    Stil available.. dropping it to final price of $185 shipped via 2-3 day shipping.
  11. irishluder
    SF BayArea
    Ill take it Mavi
  12. Mavi
    Mavi Active Member
    484
    283
    San Diego,ca
    2020 Prius Prime
    Sold. Thanks for the interest.
