size rim, wheel weight, tire spec vs fuel efficiency
Discussion in 'Gen 3 Prius Fuel Economy' started by tekstyle, Dec 21, 2014.
  1. tekstyle
    tekstyle Junior Member
    48
    seattle wa
    Lets start a thread of what your avg fuel efficiency is. This might help everyone get an idea of a goal to aim for if someone wants a balance between FE and style.
    Please post:
    Make/model of rim and weight:
    size of rim:
    tire make/model:
    total wheel weight:
    Avg temperature you do most of your driving with these wheels.
    mpg:
    Ill go first:
    2015 Prius plug-in OE wheels 18lb
    15x6 5x100 45+offset (might be wrong)
    Bridgestone ecopia
    195/65R15 44psi
    total weight: unknown
    avg temp: 57 to 61 F
    Mpg: 45-47
  2. bwilson4web
    15,523
    irrational likes this.
  3. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :)Factory 15" wheel and tire setup will give you the best fuel mileage. I have the 17" Toyota five spoke wheels with non LRR tires and I'm sure I get a little less fuel mileage. Exactly what, I'm not sure and with my Prius providing excellent fuel mileage, it's no big deal. I like the 17" wheels for the look and the slight fuel mileage loss is worth the better looking wheels. As Bob shows, higher speeds have a greater effect on MPG reduction.
    F8L likes this.
  4. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    You need to get responses from those who've had both, and can post their relative mileage. There are so many variables affecting fuel usage, that individual experiences will be misleading.
  5. Mendel Leisk
    38,726
    I go from Michelin Pilot 215/45R17 on OEM 5 spoke alloy rims, to Michelin X-Ice2 195/65R15 on Corolla steel rims, with no noticeable change in mpg. Guess that means the Pilots on the the porky OEM rims are about the same as snows, lol.
    The OEM rims I've guestimated around 24 lbs. This was by weighing the tire/rim assembly (with decent digital luggage scale) and deducting tire's spec'd weight.
    The Corolla steel rims and tires are significantly lighter, just judging from what my back tells me, when I put them on. The OEM assembly weighs maybe 10 pounds more than the snow package? I should weigh both sets, next time I get the chance.
    #5 Mendel Leisk, Dec 22, 2014
  6. tekstyle
    48
    seattle wa
    Wow. I actually like the 5 spokes but didn't know they were that heavy. Thanks for the info.
  7. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The weight is effectively irrelevant in the case of the Prius. Wheel size, however, isn't. To make your request much simpler just assume you will average 45-50mpg on 17" wheels with LRR tires and 50-55mpg on 15" tires. The error of margin is +- 2mpg. Most people lose 4-6mpg with 17" or larger wheels. Wheel Weight doesn't seem to matter although lighter is better for overall performance.
    Pete44 likes this.
  8. tekstyle
    48
    seattle wa
    So are you saying a 15" rim/tire combo vs a 17" rim/tire combo even at the same outer diameter, yield similar rev/mile and same total wheel weight.... the 15" will still come out higher mpg?
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Yup. :)
    The mpg losses are found in the hysteresis of the tires. 17" tires are less efficient and in most cases wider so you get an aerodynamic hit as well.
    The problem is finding wheels that are cool looking, affordable and only weight 11lbs. Because 17" tires are generally 3-4lbs heavier than 15" tires, you will need to find a super lightweight 17" to compensate for heavier tires. Unfortunately, people have tried super expensive 15" wheels and noticed no significant gain in fuel economy over the OE 15" wheels.
    If you could build a custom 17" wheel with a narrow width and produce a LRR tire to fit it then you can overcome all these losses. I believe BMW did this with the i3 and their 19" or 20" wheels. Hard to say for sure since they can't run a 15" wheel and their wheels won't fit a Prius. A quick test swap would be cool.
  10. DieselHammer
    DieselHammer Junior Member
    23
    Kansas and Texas
    Hi Mendel, what year of Corolla wheels work with Gen 3 Prius?
    Are the steel Corolla wheels less weight than the steel Prius wheels?
  11. Tideland Prius
    16,155
    Any year from 2003 to 2022 with 15" wheels use the same 5x100 bolt pattern.
    Should be the same weight since they're the same size. The Prius never came with steel rims, always alloys so replacing a 15" alloy wheel on a Gen 3 with a steel rim will see the weight increase.
